读写spiffs和littlefs均会导致屏幕错位,现象如图,配置如下:
* Automatically generated file. DO NOT EDIT.
* Espressif IoT Development Framework (ESP-IDF) Configuration Header
#pragma once
#define CONFIG_SOC_LEDC_SUPPORT_APB_CLOCK 1
#define CONFIG_SOC_LEDC_SUPPORT_XTAL_CLOCK 1
#define CONFIG_SOC_LEDC_CHANNEL_NUM 8
#define CONFIG_SOC_LEDC_TIMER_BIT_WIDE_NUM 14
#define CONFIG_SOC_LEDC_SUPPORT_FADE_STOP 1
#define CONFIG_SOC_MPU_MIN_REGION_SIZE 0x20000000
#define CONFIG_SOC_MPU_REGIONS_MAX_NUM 8
#define CONFIG_SOC_ADC_SUPPORTED 1
#define CONFIG_SOC_PCNT_SUPPORTED 1
#define CONFIG_SOC_WIFI_SUPPORTED 1
#define CONFIG_SOC_TWAI_SUPPORTED 1
#define CONFIG_SOC_GDMA_SUPPORTED 1
#define CONFIG_SOC_LCDCAM_SUPPORTED 1
#define CONFIG_SOC_MCPWM_SUPPORTED 1
#define CONFIG_SOC_DEDICATED_GPIO_SUPPORTED 1
#define CONFIG_SOC_CACHE_SUPPORT_WRAP 1
#define CONFIG_SOC_ULP_SUPPORTED 1
#define CONFIG_SOC_RISCV_COPROC_SUPPORTED 1
#define CONFIG_SOC_BT_SUPPORTED 1
#define CONFIG_SOC_USB_OTG_SUPPORTED 1
#define CONFIG_SOC_USB_SERIAL_JTAG_SUPPORTED 1
#define CONFIG_SOC_CCOMP_TIMER_SUPPORTED 1
#define CONFIG_SOC_ASYNC_MEMCPY_SUPPORTED 1
#define CONFIG_SOC_SUPPORTS_SECURE_DL_MODE 1
#define CONFIG_SOC_EFUSE_KEY_PURPOSE_FIELD 1
#define CONFIG_SOC_SDMMC_HOST_SUPPORTED 1
#define CONFIG_SOC_RTC_FAST_MEM_SUPPORTED 1
#define CONFIG_SOC_RTC_SLOW_MEM_SUPPORTED 1
#define CONFIG_SOC_RTC_MEM_SUPPORTED 1
#define CONFIG_SOC_PSRAM_DMA_CAPABLE 1
#define CONFIG_SOC_XT_WDT_SUPPORTED 1
#define CONFIG_SOC_I2S_SUPPORTED 1
#define CONFIG_SOC_RMT_SUPPORTED 1
#define CONFIG_SOC_SDM_SUPPORTED 1
#define CONFIG_SOC_SYSTIMER_SUPPORTED 1
#define CONFIG_SOC_SUPPORT_COEXISTENCE 1
#define CONFIG_SOC_TEMP_SENSOR_SUPPORTED 1
#define CONFIG_SOC_AES_SUPPORTED 1
#define CONFIG_SOC_MPI_SUPPORTED 1
#define CONFIG_SOC_SHA_SUPPORTED 1
#define CONFIG_SOC_HMAC_SUPPORTED 1
#define CONFIG_SOC_DIG_SIGN_SUPPORTED 1
#define CONFIG_SOC_FLASH_ENC_SUPPORTED 1
#define CONFIG_SOC_SECURE_BOOT_SUPPORTED 1
#define CONFIG_SOC_MEMPROT_SUPPORTED 1
#define CONFIG_SOC_TOUCH_SENSOR_SUPPORTED 1
#define CONFIG_SOC_XTAL_SUPPORT_40M 1
#define CONFIG_SOC_APPCPU_HAS_CLOCK_GATING_BUG 1
#define CONFIG_SOC_ADC_RTC_CTRL_SUPPORTED 1
#define CONFIG_SOC_ADC_DIG_CTRL_SUPPORTED 1
#define CONFIG_SOC_ADC_ARBITER_SUPPORTED 1
#define CONFIG_SOC_ADC_FILTER_SUPPORTED 1
#define CONFIG_SOC_ADC_MONITOR_SUPPORTED 1
#define CONFIG_SOC_ADC_DMA_SUPPORTED 1
#define CONFIG_SOC_ADC_PERIPH_NUM 2
#define CONFIG_SOC_ADC_MAX_CHANNEL_NUM 10
#define CONFIG_SOC_ADC_ATTEN_NUM 4
#define CONFIG_SOC_ADC_DIGI_CONTROLLER_NUM 2
#define CONFIG_SOC_ADC_PATT_LEN_MAX 24
#define CONFIG_SOC_ADC_DIGI_MIN_BITWIDTH 12
#define CONFIG_SOC_ADC_DIGI_MAX_BITWIDTH 12
#define CONFIG_SOC_ADC_DIGI_RESULT_BYTES 4
#define CONFIG_SOC_ADC_DIGI_DATA_BYTES_PER_CONV 4
#define CONFIG_SOC_ADC_SAMPLE_FREQ_THRES_HIGH 83333
#define CONFIG_SOC_ADC_SAMPLE_FREQ_THRES_LOW 611
#define CONFIG_SOC_ADC_RTC_MIN_BITWIDTH 12
#define CONFIG_SOC_ADC_RTC_MAX_BITWIDTH 12
#define CONFIG_SOC_RTC_SLOW_CLOCK_SUPPORT_8MD256 1
#define CONFIG_SOC_ADC_CALIBRATION_V1_SUPPORTED 1
#define CONFIG_SOC_APB_BACKUP_DMA 1
#define CONFIG_SOC_BROWNOUT_RESET_SUPPORTED 1
#define CONFIG_SOC_MMU_LINEAR_ADDRESS_REGION_NUM 1
#define CONFIG_SOC_CPU_CORES_NUM 2
#define CONFIG_SOC_CPU_INTR_NUM 32
#define CONFIG_SOC_CPU_HAS_FPU 1
#define CONFIG_SOC_CPU_BREAKPOINTS_NUM 2
#define CONFIG_SOC_CPU_WATCHPOINTS_NUM 2
#define CONFIG_SOC_CPU_WATCHPOINT_SIZE 64
#define CONFIG_SOC_DS_SIGNATURE_MAX_BIT_LEN 4096
#define CONFIG_SOC_DS_KEY_PARAM_MD_IV_LENGTH 16
#define CONFIG_SOC_DS_KEY_CHECK_MAX_WAIT_US 1100
#define CONFIG_SOC_GDMA_GROUPS 1
#define CONFIG_SOC_GDMA_PAIRS_PER_GROUP 5
#define CONFIG_SOC_GDMA_SUPPORT_PSRAM 1
#define CONFIG_SOC_GDMA_PSRAM_MIN_ALIGN 16
#define CONFIG_SOC_GPIO_PORT 1
#define CONFIG_SOC_GPIO_PIN_COUNT 49
#define CONFIG_SOC_GPIO_SUPPORT_RTC_INDEPENDENT 1
#define CONFIG_SOC_GPIO_SUPPORT_FORCE_HOLD 1
#define CONFIG_SOC_GPIO_VALID_GPIO_MASK 0x1FFFFFFFFFFFF
#define CONFIG_SOC_GPIO_SUPPORT_SLP_SWITCH 1
#define CONFIG_SOC_DEDIC_GPIO_OUT_CHANNELS_NUM 8
#define CONFIG_SOC_DEDIC_GPIO_IN_CHANNELS_NUM 8
#define CONFIG_SOC_DEDIC_GPIO_OUT_AUTO_ENABLE 1
#define CONFIG_SOC_I2C_NUM 2
#define CONFIG_SOC_I2C_FIFO_LEN 32
#define CONFIG_SOC_I2C_SUPPORT_SLAVE 1
#define CONFIG_SOC_I2C_SUPPORT_HW_CLR_BUS 1
#define CONFIG_SOC_I2C_SUPPORT_XTAL 1
#define CONFIG_SOC_I2C_SUPPORT_RTC 1
#define CONFIG_SOC_I2S_NUM 2
#define CONFIG_SOC_I2S_HW_VERSION_2 1
#define CONFIG_SOC_I2S_SUPPORTS_PCM 1
#define CONFIG_SOC_I2S_SUPPORTS_PDM 1
#define CONFIG_SOC_I2S_SUPPORTS_PDM_TX 1
#define CONFIG_SOC_I2S_SUPPORTS_PDM_RX 1
#define CONFIG_SOC_I2S_SUPPORTS_PDM_CODEC 1
#define CONFIG_SOC_I2S_SUPPORTS_TDM 1
#define CONFIG_SOC_MCPWM_GROUPS 2
#define CONFIG_SOC_MCPWM_TIMERS_PER_GROUP 3
#define CONFIG_SOC_MCPWM_OPERATORS_PER_GROUP 3
#define CONFIG_SOC_MCPWM_COMPARATORS_PER_OPERATOR 2
#define CONFIG_SOC_MCPWM_GENERATORS_PER_OPERATOR 2
#define CONFIG_SOC_MCPWM_TRIGGERS_PER_OPERATOR 2
#define CONFIG_SOC_MCPWM_GPIO_FAULTS_PER_GROUP 3
#define CONFIG_SOC_MCPWM_CAPTURE_TIMERS_PER_GROUP 1
#define CONFIG_SOC_MCPWM_CAPTURE_CHANNELS_PER_TIMER 3
#define CONFIG_SOC_MCPWM_GPIO_SYNCHROS_PER_GROUP 3
#define CONFIG_SOC_MCPWM_SWSYNC_CAN_PROPAGATE 1
#define CONFIG_SOC_PCNT_GROUPS 1
#define CONFIG_SOC_PCNT_UNITS_PER_GROUP 4
#define CONFIG_SOC_PCNT_CHANNELS_PER_UNIT 2
#define CONFIG_SOC_PCNT_THRES_POINT_PER_UNIT 2
#define CONFIG_SOC_RMT_GROUPS 1
#define CONFIG_SOC_RMT_TX_CANDIDATES_PER_GROUP 4
#define CONFIG_SOC_RMT_RX_CANDIDATES_PER_GROUP 4
#define CONFIG_SOC_RMT_CHANNELS_PER_GROUP 8
#define CONFIG_SOC_RMT_MEM_WORDS_PER_CHANNEL 48
#define CONFIG_SOC_RMT_SUPPORT_RX_PINGPONG 1
#define CONFIG_SOC_RMT_SUPPORT_RX_DEMODULATION 1
#define CONFIG_SOC_RMT_SUPPORT_TX_ASYNC_STOP 1
#define CONFIG_SOC_RMT_SUPPORT_TX_LOOP_COUNT 1
#define CONFIG_SOC_RMT_SUPPORT_TX_LOOP_AUTO_STOP 1
#define CONFIG_SOC_RMT_SUPPORT_TX_SYNCHRO 1
#define CONFIG_SOC_RMT_SUPPORT_TX_CARRIER_DATA_ONLY 1
#define CONFIG_SOC_RMT_SUPPORT_XTAL 1
#define CONFIG_SOC_RMT_SUPPORT_RC_FAST 1
#define CONFIG_SOC_RMT_SUPPORT_APB 1
#define CONFIG_SOC_RMT_SUPPORT_DMA 1
#define CONFIG_SOC_LCD_I80_SUPPORTED 1
#define CONFIG_SOC_LCD_RGB_SUPPORTED 1
#define CONFIG_SOC_LCD_I80_BUSES 1
#define CONFIG_SOC_LCD_RGB_PANELS 1
#define CONFIG_SOC_LCD_I80_BUS_WIDTH 16
#define CONFIG_SOC_LCD_RGB_DATA_WIDTH 16
#define CONFIG_SOC_LCD_SUPPORT_RGB_YUV_CONV 1
#define CONFIG_SOC_RTC_CNTL_CPU_PD_DMA_BUS_WIDTH 128
#define CONFIG_SOC_RTC_CNTL_CPU_PD_REG_FILE_NUM 549
#define CONFIG_SOC_RTC_CNTL_TAGMEM_PD_DMA_BUS_WIDTH 128
#define CONFIG_SOC_RTCIO_PIN_COUNT 22
#define CONFIG_SOC_RTCIO_INPUT_OUTPUT_SUPPORTED 1
#define CONFIG_SOC_RTCIO_HOLD_SUPPORTED 1
#define CONFIG_SOC_RTCIO_WAKE_SUPPORTED 1
#define CONFIG_SOC_SDM_GROUPS 1
#define CONFIG_SOC_SDM_CHANNELS_PER_GROUP 8
#define CONFIG_SOC_SPI_PERIPH_NUM 3
#define CONFIG_SOC_SPI_MAX_CS_NUM 6
#define CONFIG_SOC_SPI_MAXIMUM_BUFFER_SIZE 64
#define CONFIG_SOC_SPI_SUPPORT_DDRCLK 1
#define CONFIG_SOC_SPI_SLAVE_SUPPORT_SEG_TRANS 1
#define CONFIG_SOC_SPI_SUPPORT_CD_SIG 1
#define CONFIG_SOC_SPI_SUPPORT_CONTINUOUS_TRANS 1
#define CONFIG_SOC_SPI_SUPPORT_SLAVE_HD_VER2 1
#define CONFIG_SOC_SPI_PERIPH_SUPPORT_CONTROL_DUMMY_OUT 1
#define CONFIG_SOC_MEMSPI_IS_INDEPENDENT 1
#define CONFIG_SOC_SPI_MAX_PRE_DIVIDER 16
#define CONFIG_SOC_SPI_SUPPORT_OCT 1
#define CONFIG_SOC_MEMSPI_SRC_FREQ_120M 1
#define CONFIG_SOC_MEMSPI_SRC_FREQ_80M_SUPPORTED 1
#define CONFIG_SOC_MEMSPI_SRC_FREQ_40M_SUPPORTED 1
#define CONFIG_SOC_MEMSPI_SRC_FREQ_20M_SUPPORTED 1
#define CONFIG_SOC_SPIRAM_SUPPORTED 1
#define CONFIG_SOC_SYSTIMER_COUNTER_NUM 2
#define CONFIG_SOC_SYSTIMER_ALARM_NUM 3
#define CONFIG_SOC_SYSTIMER_BIT_WIDTH_LO 32
#define CONFIG_SOC_SYSTIMER_BIT_WIDTH_HI 20
#define CONFIG_SOC_SYSTIMER_FIXED_DIVIDER 1
#define CONFIG_SOC_SYSTIMER_INT_LEVEL 1
#define CONFIG_SOC_SYSTIMER_ALARM_MISS_COMPENSATE 1
#define CONFIG_SOC_TIMER_GROUPS 2
#define CONFIG_SOC_TIMER_GROUP_TIMERS_PER_GROUP 2
#define CONFIG_SOC_TIMER_GROUP_COUNTER_BIT_WIDTH 54
#define CONFIG_SOC_TIMER_GROUP_SUPPORT_XTAL 1
#define CONFIG_SOC_TIMER_GROUP_SUPPORT_APB 1
#define CONFIG_SOC_TIMER_GROUP_TOTAL_TIMERS 4
#define CONFIG_SOC_TOUCH_VERSION_2 1
#define CONFIG_SOC_TOUCH_SENSOR_NUM 15
#define CONFIG_SOC_TOUCH_PROXIMITY_CHANNEL_NUM 3
#define CONFIG_SOC_TOUCH_PROXIMITY_MEAS_DONE_SUPPORTED 1
#define CONFIG_SOC_TOUCH_PAD_THRESHOLD_MAX 0x1FFFFF
#define CONFIG_SOC_TOUCH_PAD_MEASURE_WAIT_MAX 0xFF
#define CONFIG_SOC_UART_NUM 3
#define CONFIG_SOC_UART_FIFO_LEN 128
#define CONFIG_SOC_UART_BITRATE_MAX 5000000
#define CONFIG_SOC_UART_SUPPORT_FSM_TX_WAIT_SEND 1
#define CONFIG_SOC_UART_SUPPORT_WAKEUP_INT 1
#define CONFIG_SOC_UART_SUPPORT_APB_CLK 1
#define CONFIG_SOC_UART_SUPPORT_RTC_CLK 1
#define CONFIG_SOC_UART_SUPPORT_XTAL_CLK 1
#define CONFIG_SOC_UART_REQUIRE_CORE_RESET 1
#define CONFIG_SOC_USB_PERIPH_NUM 1
#define CONFIG_SOC_SHA_DMA_MAX_BUFFER_SIZE 3968
#define CONFIG_SOC_SHA_SUPPORT_DMA 1
#define CONFIG_SOC_SHA_SUPPORT_RESUME 1
#define CONFIG_SOC_SHA_GDMA 1
#define CONFIG_SOC_SHA_SUPPORT_SHA1 1
#define CONFIG_SOC_SHA_SUPPORT_SHA224 1
#define CONFIG_SOC_SHA_SUPPORT_SHA256 1
#define CONFIG_SOC_SHA_SUPPORT_SHA384 1
#define CONFIG_SOC_SHA_SUPPORT_SHA512 1
#define CONFIG_SOC_SHA_SUPPORT_SHA512_224 1
#define CONFIG_SOC_SHA_SUPPORT_SHA512_256 1
#define CONFIG_SOC_SHA_SUPPORT_SHA512_T 1
#define CONFIG_SOC_RSA_MAX_BIT_LEN 4096
#define CONFIG_SOC_AES_SUPPORT_DMA 1
#define CONFIG_SOC_AES_GDMA 1
#define CONFIG_SOC_AES_SUPPORT_AES_128 1
#define CONFIG_SOC_AES_SUPPORT_AES_256 1
#define CONFIG_SOC_PM_SUPPORT_EXT_WAKEUP 1
#define CONFIG_SOC_PM_SUPPORT_WIFI_WAKEUP 1
#define CONFIG_SOC_PM_SUPPORT_BT_WAKEUP 1
#define CONFIG_SOC_PM_SUPPORT_CPU_PD 1
#define CONFIG_SOC_PM_SUPPORT_TAGMEM_PD 1
#define CONFIG_SOC_PM_SUPPORT_RTC_PERIPH_PD 1
#define CONFIG_SOC_PM_SUPPORT_TOUCH_SENSOR_WAKEUP 1
#define CONFIG_SOC_PM_SUPPORT_DEEPSLEEP_CHECK_STUB_ONLY 1
#define CONFIG_SOC_SECURE_BOOT_V2_RSA 1
#define CONFIG_SOC_EFUSE_SECURE_BOOT_KEY_DIGESTS 3
#define CONFIG_SOC_EFUSE_REVOKE_BOOT_KEY_DIGESTS 1
#define CONFIG_SOC_SUPPORT_SECURE_BOOT_REVOKE_KEY 1
#define CONFIG_SOC_FLASH_ENCRYPTED_XTS_AES_BLOCK_MAX 64
#define CONFIG_SOC_FLASH_ENCRYPTION_XTS_AES 1
#define CONFIG_SOC_FLASH_ENCRYPTION_XTS_AES_OPTIONS 1
#define CONFIG_SOC_FLASH_ENCRYPTION_XTS_AES_128 1
#define CONFIG_SOC_FLASH_ENCRYPTION_XTS_AES_256 1
#define CONFIG_SOC_MEMPROT_CPU_PREFETCH_PAD_SIZE 16
#define CONFIG_SOC_MEMPROT_MEM_ALIGN_SIZE 256
#define CONFIG_SOC_PHY_DIG_REGS_MEM_SIZE 21
#define CONFIG_SOC_MAC_BB_PD_MEM_SIZE 192
#define CONFIG_SOC_WIFI_LIGHT_SLEEP_CLK_WIDTH 12
#define CONFIG_SOC_SPI_MEM_SUPPORT_AUTO_WAIT_IDLE 1
#define CONFIG_SOC_SPI_MEM_SUPPORT_AUTO_SUSPEND 1
#define CONFIG_SOC_SPI_MEM_SUPPORT_AUTO_RESUME 1
#define CONFIG_SOC_SPI_MEM_SUPPORT_SW_SUSPEND 1
#define CONFIG_SOC_SPI_MEM_SUPPORT_OPI_MODE 1
#define CONFIG_SOC_SPI_MEM_SUPPORT_TIME_TUNING 1
#define CONFIG_SOC_SPI_MEM_SUPPORT_CONFIG_GPIO_BY_EFUSE 1
#define CONFIG_SOC_COEX_HW_PTI 1
#define CONFIG_SOC_SDMMC_USE_GPIO_MATRIX 1
#define CONFIG_SOC_SDMMC_NUM_SLOTS 2
#define CONFIG_SOC_SDMMC_SUPPORT_XTAL_CLOCK 1
#define CONFIG_SOC_TEMPERATURE_SENSOR_SUPPORT_FAST_RC 1
#define CONFIG_SOC_WIFI_HW_TSF 1
#define CONFIG_SOC_WIFI_FTM_SUPPORT 1
#define CONFIG_SOC_WIFI_GCMP_SUPPORT 1
#define CONFIG_SOC_WIFI_WAPI_SUPPORT 1
#define CONFIG_SOC_WIFI_CSI_SUPPORT 1
#define CONFIG_SOC_WIFI_MESH_SUPPORT 1
#define CONFIG_SOC_BLE_SUPPORTED 1
#define CONFIG_SOC_BLE_MESH_SUPPORTED 1
#define CONFIG_SOC_TWAI_BRP_MIN 2
#define CONFIG_SOC_TWAI_BRP_MAX 16384
#define CONFIG_SOC_TWAI_SUPPORTS_RX_STATUS 1
#define CONFIG_IDF_CMAKE 1
#define CONFIG_IDF_TARGET_ARCH_XTENSA 1
#define CONFIG_IDF_TARGET_ARCH "xtensa"
#define CONFIG_IDF_TARGET "esp32s3"
#define CONFIG_IDF_TARGET_ESP32S3 1
#define CONFIG_IDF_FIRMWARE_CHIP_ID 0x0009
#define CONFIG_APP_BUILD_TYPE_APP_2NDBOOT 1
#define CONFIG_APP_BUILD_GENERATE_BINARIES 1
#define CONFIG_APP_BUILD_BOOTLOADER 1
#define CONFIG_APP_BUILD_USE_FLASH_SECTIONS 1
#define CONFIG_BOOTLOADER_OFFSET_IN_FLASH 0x0
#define CONFIG_BOOTLOADER_COMPILER_OPTIMIZATION_SIZE 1
#define CONFIG_BOOTLOADER_LOG_LEVEL_INFO 1
#define CONFIG_BOOTLOADER_LOG_LEVEL 3
#define CONFIG_BOOTLOADER_VDDSDIO_BOOST_1_9V 1
#define CONFIG_BOOTLOADER_REGION_PROTECTION_ENABLE 1
#define CONFIG_BOOTLOADER_WDT_ENABLE 1
#define CONFIG_BOOTLOADER_WDT_TIME_MS 9000
#define CONFIG_BOOTLOADER_RESERVE_RTC_SIZE 0x0
#define CONFIG_BOOTLOADER_FLASH_XMC_SUPPORT 1
#define CONFIG_SECURE_BOOT_V2_RSA_SUPPORTED 1
#define CONFIG_SECURE_BOOT_V2_PREFERRED 1
#define CONFIG_SECURE_ROM_DL_MODE_ENABLED 1
#define CONFIG_APP_COMPILE_TIME_DATE 1
#define CONFIG_APP_RETRIEVE_LEN_ELF_SHA 16
#define CONFIG_ESP_ROM_HAS_CRC_LE 1
#define CONFIG_ESP_ROM_HAS_CRC_BE 1
#define CONFIG_ESP_ROM_HAS_JPEG_DECODE 1
#define CONFIG_ESP_ROM_SUPPORT_MULTIPLE_UART 1
#define CONFIG_ESP_ROM_UART_CLK_IS_XTAL 1
#define CONFIG_ESP_ROM_HAS_RETARGETABLE_LOCKING 1
#define CONFIG_ESP_ROM_USB_SERIAL_DEVICE_NUM 4
#define CONFIG_ESP_ROM_HAS_ERASE_0_REGION_BUG 1
#define CONFIG_ESP_ROM_GET_CLK_FREQ 1
#define CONFIG_ESP_ROM_HAS_HAL_WDT 1
#define CONFIG_ESP_ROM_NEEDS_SWSETUP_WORKAROUND 1
#define CONFIG_BOOT_ROM_LOG_ALWAYS_ON 1
#define CONFIG_ESPTOOLPY_FLASHMODE_DIO 1
#define CONFIG_ESPTOOLPY_FLASH_SAMPLE_MODE_STR 1
#define CONFIG_ESPTOOLPY_FLASHMODE "dio"
#define CONFIG_ESPTOOLPY_FLASHFREQ_80M 1
#define CONFIG_ESPTOOLPY_FLASHFREQ "80m"
#define CONFIG_ESPTOOLPY_FLASHSIZE_16MB 1
#define CONFIG_ESPTOOLPY_FLASHSIZE "16MB"
#define CONFIG_ESPTOOLPY_BEFORE_RESET 1
#define CONFIG_ESPTOOLPY_BEFORE "default_reset"
#define CONFIG_ESPTOOLPY_AFTER_RESET 1
#define CONFIG_ESPTOOLPY_AFTER "hard_reset"
#define CONFIG_ESPTOOLPY_MONITOR_BAUD 115200
#define CONFIG_PARTITION_TABLE_CUSTOM 1
#define CONFIG_PARTITION_TABLE_CUSTOM_FILENAME "partitions.csv"
#define CONFIG_PARTITION_TABLE_FILENAME "partitions.csv"
#define CONFIG_PARTITION_TABLE_OFFSET 0x8000
#define CONFIG_PARTITION_TABLE_MD5 1
#define CONFIG_COMPILER_OPTIMIZATION_PERF 1
#define CONFIG_COMPILER_OPTIMIZATION_ASSERTIONS_ENABLE 1
#define CONFIG_COMPILER_FLOAT_LIB_FROM_GCCLIB 1
#define CONFIG_COMPILER_OPTIMIZATION_ASSERTION_LEVEL 2
#define CONFIG_COMPILER_HIDE_PATHS_MACROS 1
#define CONFIG_COMPILER_STACK_CHECK_MODE_NONE 1
#define CONFIG_APPTRACE_DEST_NONE 1
#define CONFIG_APPTRACE_DEST_UART_NONE 1
#define CONFIG_APPTRACE_UART_TASK_PRIO 1
#define CONFIG_APPTRACE_LOCK_ENABLE 1
#define CONFIG_SPI_MASTER_ISR_IN_IRAM 1
#define CONFIG_SPI_SLAVE_ISR_IN_IRAM 1
#define CONFIG_EFUSE_MAX_BLK_LEN 256
#define CONFIG_ESP_TLS_USING_MBEDTLS 1
#define CONFIG_ESP_TLS_USE_DS_PERIPHERAL 1
#define CONFIG_ESP_ERR_TO_NAME_LOOKUP 1
#define CONFIG_ETH_ENABLED 1
#define CONFIG_ETH_USE_SPI_ETHERNET 1
#define CONFIG_ESP_EVENT_POST_FROM_ISR 1
#define CONFIG_ESP_EVENT_POST_FROM_IRAM_ISR 1
#define CONFIG_ESP_HTTP_CLIENT_ENABLE_HTTPS 1
#define CONFIG_HTTPD_MAX_REQ_HDR_LEN 512
#define CONFIG_HTTPD_MAX_URI_LEN 512
#define CONFIG_HTTPD_ERR_RESP_NO_DELAY 1
#define CONFIG_HTTPD_PURGE_BUF_LEN 32
#define CONFIG_ESP_MAC_ADDR_UNIVERSE_WIFI_STA 1
#define CONFIG_ESP_MAC_ADDR_UNIVERSE_WIFI_AP 1
#define CONFIG_ESP_MAC_ADDR_UNIVERSE_BT 1
#define CONFIG_ESP_MAC_ADDR_UNIVERSE_ETH 1
#define CONFIG_ESP32S3_UNIVERSAL_MAC_ADDRESSES_FOUR 1
#define CONFIG_ESP32S3_UNIVERSAL_MAC_ADDRESSES 4
#define CONFIG_ESP_SLEEP_RTC_BUS_ISO_WORKAROUND 1
#define CONFIG_ESP_SLEEP_GPIO_RESET_WORKAROUND 1
#define CONFIG_ESP_SLEEP_PSRAM_LEAKAGE_WORKAROUND 1
#define CONFIG_ESP_SLEEP_FLASH_LEAKAGE_WORKAROUND 1
#define CONFIG_ESP_SLEEP_MSPI_NEED_ALL_IO_PU 1
#define CONFIG_ESP_SLEEP_DEEP_SLEEP_WAKEUP_DELAY 2000
#define CONFIG_RTC_CLK_SRC_INT_RC 1
#define CONFIG_RTC_CLK_CAL_CYCLES 1024
#define CONFIG_RTC_CLOCK_BBPLL_POWER_ON_WITH_USB 1
#define CONFIG_MMU_PAGE_SIZE_64KB 1
#define CONFIG_MMU_PAGE_MODE "64KB"
#define CONFIG_MMU_PAGE_SIZE 0x10000
#define CONFIG_XTAL_FREQ_40 1
#define CONFIG_XTAL_FREQ 40
#define CONFIG_LCD_PANEL_IO_FORMAT_BUF_SIZE 32
#define CONFIG_ESP_NETIF_IP_LOST_TIMER_INTERVAL 120
#define CONFIG_ESP_NETIF_TCPIP_LWIP 1
#define CONFIG_ESP_PHY_CALIBRATION_AND_DATA_STORAGE 1
#define CONFIG_ESP_PHY_MAX_WIFI_TX_POWER 20
#define CONFIG_ESP_PHY_MAX_TX_POWER 20
#define CONFIG_ESP_PHY_REDUCE_TX_POWER 1
#define CONFIG_ESP_PHY_ENABLE_USB 1
#define CONFIG_PM_POWER_DOWN_CPU_IN_LIGHT_SLEEP 1
#define CONFIG_PM_POWER_DOWN_TAGMEM_IN_LIGHT_SLEEP 1
#define CONFIG_SPIRAM 1
#define CONFIG_SPIRAM_MODE_OCT 1
#define CONFIG_SPIRAM_TYPE_AUTO 1
#define CONFIG_SPIRAM_ALLOW_STACK_EXTERNAL_MEMORY 1
#define CONFIG_DEFAULT_PSRAM_CLK_IO 30
#define CONFIG_DEFAULT_PSRAM_CS_IO 26
#define CONFIG_SPIRAM_FETCH_INSTRUCTIONS 1
#define CONFIG_SPIRAM_RODATA 1
#define CONFIG_SPIRAM_SPEED_80M 1
#define CONFIG_SPIRAM_SPEED 80
#define CONFIG_SPIRAM_BOOT_INIT 1
#define CONFIG_SPIRAM_USE_MALLOC 1
#define CONFIG_SPIRAM_MEMTEST 1
#define CONFIG_SPIRAM_MALLOC_ALWAYSINTERNAL 16384
#define CONFIG_SPIRAM_MALLOC_RESERVE_INTERNAL 262144
#define CONFIG_ESP_DEFAULT_CPU_FREQ_MHZ_240 1
#define CONFIG_ESP_DEFAULT_CPU_FREQ_MHZ 240
#define CONFIG_ESP32S3_INSTRUCTION_CACHE_16KB 1
#define CONFIG_ESP32S3_INSTRUCTION_CACHE_SIZE 0x4000
#define CONFIG_ESP32S3_INSTRUCTION_CACHE_8WAYS 1
#define CONFIG_ESP32S3_ICACHE_ASSOCIATED_WAYS 8
#define CONFIG_ESP32S3_INSTRUCTION_CACHE_LINE_32B 1
#define CONFIG_ESP32S3_INSTRUCTION_CACHE_LINE_SIZE 32
#define CONFIG_ESP32S3_DATA_CACHE_32KB 1
#define CONFIG_ESP32S3_DATA_CACHE_SIZE 0x8000
#define CONFIG_ESP32S3_DATA_CACHE_8WAYS 1
#define CONFIG_ESP32S3_DCACHE_ASSOCIATED_WAYS 8
#define CONFIG_ESP32S3_DATA_CACHE_LINE_32B 1
#define CONFIG_ESP32S3_DATA_CACHE_LINE_SIZE 32
#define CONFIG_ESP32S3_TRACEMEM_RESERVE_DRAM 0x0
#define CONFIG_ESP_SYSTEM_PANIC_PRINT_REBOOT 1
#define CONFIG_ESP_SYSTEM_RTC_FAST_MEM_AS_HEAP_DEPCHECK 1
#define CONFIG_ESP_SYSTEM_ALLOW_RTC_FAST_MEM_AS_HEAP 1
#define CONFIG_ESP_SYSTEM_MEMPROT_FEATURE 1
#define CONFIG_ESP_SYSTEM_MEMPROT_FEATURE_LOCK 1
#define CONFIG_ESP_SYSTEM_EVENT_QUEUE_SIZE 32
#define CONFIG_ESP_SYSTEM_EVENT_TASK_STACK_SIZE 2304
#define CONFIG_ESP_MAIN_TASK_STACK_SIZE 3584
#define CONFIG_ESP_MAIN_TASK_AFFINITY_CPU0 1
#define CONFIG_ESP_MAIN_TASK_AFFINITY 0x0
#define CONFIG_ESP_MINIMAL_SHARED_STACK_SIZE 2048
#define CONFIG_ESP_CONSOLE_USB_SERIAL_JTAG 1
#define CONFIG_ESP_CONSOLE_SECONDARY_NONE 1
#define CONFIG_ESP_CONSOLE_MULTIPLE_UART 1
#define CONFIG_ESP_CONSOLE_UART_NUM -1
#define CONFIG_ESP_DEBUG_OCDAWARE 1
#define CONFIG_ESP_SYSTEM_CHECK_INT_LEVEL_4 1
#define CONFIG_ESP_BROWNOUT_DET 1
#define CONFIG_ESP_BROWNOUT_DET_LVL_SEL_7 1
#define CONFIG_ESP_BROWNOUT_DET_LVL 7
#define CONFIG_ESP_SYSTEM_BROWNOUT_INTR 1
#define CONFIG_ESP_IPC_TASK_STACK_SIZE 1280
#define CONFIG_ESP_IPC_USES_CALLERS_PRIORITY 1
#define CONFIG_ESP_IPC_ISR_ENABLE 1
#define CONFIG_ESP_TIME_FUNCS_USE_RTC_TIMER 1
#define CONFIG_ESP_TIME_FUNCS_USE_ESP_TIMER 1
#define CONFIG_ESP_TIMER_TASK_STACK_SIZE 3584
#define CONFIG_ESP_TIMER_INTERRUPT_LEVEL 1
#define CONFIG_ESP_TIMER_IMPL_SYSTIMER 1
#define CONFIG_ESP32_WIFI_ENABLED 1
#define CONFIG_ESP32_WIFI_STATIC_RX_BUFFER_NUM 10
#define CONFIG_ESP32_WIFI_DYNAMIC_RX_BUFFER_NUM 32
#define CONFIG_ESP32_WIFI_STATIC_TX_BUFFER 1
#define CONFIG_ESP32_WIFI_TX_BUFFER_TYPE 0
#define CONFIG_ESP32_WIFI_STATIC_TX_BUFFER_NUM 16
#define CONFIG_ESP32_WIFI_CACHE_TX_BUFFER_NUM 32
#define CONFIG_ESP32_WIFI_AMPDU_TX_ENABLED 1
#define CONFIG_ESP32_WIFI_TX_BA_WIN 6
#define CONFIG_ESP32_WIFI_AMPDU_RX_ENABLED 1
#define CONFIG_ESP32_WIFI_RX_BA_WIN 6
#define CONFIG_ESP32_WIFI_NVS_ENABLED 1
#define CONFIG_ESP32_WIFI_TASK_PINNED_TO_CORE_0 1
#define CONFIG_ESP32_WIFI_SOFTAP_BEACON_MAX_LEN 752
#define CONFIG_ESP32_WIFI_MGMT_SBUF_NUM 32
#define CONFIG_ESP32_WIFI_IRAM_OPT 1
#define CONFIG_ESP32_WIFI_RX_IRAM_OPT 1
#define CONFIG_ESP32_WIFI_ENABLE_WPA3_SAE 1
#define CONFIG_ESP32_WIFI_ENABLE_WPA3_OWE_STA 1
#define CONFIG_ESP_WIFI_SOFTAP_SUPPORT 1
#define CONFIG_ESP_COREDUMP_ENABLE_TO_NONE 1
#define CONFIG_FATFS_VOLUME_COUNT 2
#define CONFIG_FATFS_SECTOR_4096 1
#define CONFIG_FATFS_SECTORS_PER_CLUSTER_1 1
#define CONFIG_FATFS_CODEPAGE_437 1
#define CONFIG_FATFS_AUTO_TYPE 1
#define CONFIG_FATFS_CODEPAGE 437
#define CONFIG_FATFS_LFN_NONE 1
#define CONFIG_FATFS_FS_LOCK 0
#define CONFIG_FATFS_TIMEOUT_MS 10000
#define CONFIG_FATFS_PER_FILE_CACHE 1
#define CONFIG_FATFS_ALLOC_PREFER_EXTRAM 1
#define CONFIG_FREERTOS_HZ 100
#define CONFIG_FREERTOS_CHECK_STACKOVERFLOW_CANARY 1
#define CONFIG_FREERTOS_THREAD_LOCAL_STORAGE_POINTERS 1
#define CONFIG_FREERTOS_IDLE_TASK_STACKSIZE 1536
#define CONFIG_FREERTOS_MAX_TASK_NAME_LEN 16
#define CONFIG_FREERTOS_TIMER_TASK_PRIORITY 1
#define CONFIG_FREERTOS_TIMER_TASK_STACK_DEPTH 2048
#define CONFIG_FREERTOS_TIMER_QUEUE_LENGTH 10
#define CONFIG_FREERTOS_QUEUE_REGISTRY_SIZE 0
#define CONFIG_FREERTOS_CHECK_MUTEX_GIVEN_BY_OWNER 1
#define CONFIG_FREERTOS_ISR_STACKSIZE 1536
#define CONFIG_FREERTOS_INTERRUPT_BACKTRACE 1
#define CONFIG_FREERTOS_TICK_SUPPORT_SYSTIMER 1
#define CONFIG_FREERTOS_CORETIMER_SYSTIMER_LVL1 1
#define CONFIG_FREERTOS_SYSTICK_USES_SYSTIMER 1
#define CONFIG_FREERTOS_ASSERT_ON_UNTESTED_FUNCTION 1
#define CONFIG_FREERTOS_ENABLE_TASK_SNAPSHOT 1
#define CONFIG_FREERTOS_NO_AFFINITY 0x7FFFFFFF
#define CONFIG_FREERTOS_SUPPORT_STATIC_ALLOCATION 1
#define CONFIG_FREERTOS_DEBUG_OCDAWARE 1
#define CONFIG_HAL_ASSERTION_EQUALS_SYSTEM 1
#define CONFIG_HAL_DEFAULT_ASSERTION_LEVEL 2
#define CONFIG_HAL_WDT_USE_ROM_IMPL 1
#define CONFIG_HEAP_POISONING_DISABLED 1
#define CONFIG_HEAP_TRACING_OFF 1
#define CONFIG_LOG_DEFAULT_LEVEL_DEBUG 1
#define CONFIG_LOG_DEFAULT_LEVEL 4
#define CONFIG_LOG_MAXIMUM_EQUALS_DEFAULT 1
#define CONFIG_LOG_MAXIMUM_LEVEL 4
#define CONFIG_LOG_COLORS 1
#define CONFIG_LOG_TIMESTAMP_SOURCE_RTOS 1
#define CONFIG_LWIP_LOCAL_HOSTNAME "espressif"
#define CONFIG_LWIP_DNS_SUPPORT_MDNS_QUERIES 1
#define CONFIG_LWIP_TIMERS_ONDEMAND 1
#define CONFIG_LWIP_MAX_SOCKETS 10
#define CONFIG_LWIP_SO_REUSE 1
#define CONFIG_LWIP_SO_REUSE_RXTOALL 1
#define CONFIG_LWIP_IP4_FRAG 1
#define CONFIG_LWIP_IP6_FRAG 1
#define CONFIG_LWIP_ESP_GRATUITOUS_ARP 1
#define CONFIG_LWIP_GARP_TMR_INTERVAL 60
#define CONFIG_LWIP_TCPIP_RECVMBOX_SIZE 32
#define CONFIG_LWIP_DHCP_DOES_ARP_CHECK 1
#define CONFIG_LWIP_DHCP_DISABLE_VENDOR_CLASS_ID 1
#define CONFIG_LWIP_DHCP_OPTIONS_LEN 68
#define CONFIG_LWIP_NUM_NETIF_CLIENT_DATA 0
#define CONFIG_LWIP_DHCPS 1
#define CONFIG_LWIP_DHCPS_LEASE_UNIT 60
#define CONFIG_LWIP_DHCPS_MAX_STATION_NUM 8
#define CONFIG_LWIP_IPV6 1
#define CONFIG_LWIP_IPV6_NUM_ADDRESSES 3
#define CONFIG_LWIP_NETIF_LOOPBACK 1
#define CONFIG_LWIP_LOOPBACK_MAX_PBUFS 8
#define CONFIG_LWIP_MAX_ACTIVE_TCP 16
#define CONFIG_LWIP_MAX_LISTENING_TCP 16
#define CONFIG_LWIP_TCP_HIGH_SPEED_RETRANSMISSION 1
#define CONFIG_LWIP_TCP_MAXRTX 12
#define CONFIG_LWIP_TCP_SYNMAXRTX 12
#define CONFIG_LWIP_TCP_MSS 1440
#define CONFIG_LWIP_TCP_TMR_INTERVAL 250
#define CONFIG_LWIP_TCP_MSL 60000
#define CONFIG_LWIP_TCP_FIN_WAIT_TIMEOUT 20000
#define CONFIG_LWIP_TCP_SND_BUF_DEFAULT 5744
#define CONFIG_LWIP_TCP_WND_DEFAULT 5744
#define CONFIG_LWIP_TCP_RECVMBOX_SIZE 6
#define CONFIG_LWIP_TCP_QUEUE_OOSEQ 1
#define CONFIG_LWIP_TCP_OVERSIZE_MSS 1
#define CONFIG_LWIP_TCP_RTO_TIME 1500
#define CONFIG_LWIP_MAX_UDP_PCBS 16
#define CONFIG_LWIP_UDP_RECVMBOX_SIZE 6
#define CONFIG_LWIP_CHECKSUM_CHECK_ICMP 1
#define CONFIG_LWIP_TCPIP_TASK_STACK_SIZE 3072
#define CONFIG_LWIP_TCPIP_TASK_AFFINITY_NO_AFFINITY 1
#define CONFIG_LWIP_TCPIP_TASK_AFFINITY 0x7FFFFFFF
#define CONFIG_LWIP_IPV6_MEMP_NUM_ND6_QUEUE 3
#define CONFIG_LWIP_IPV6_ND6_NUM_NEIGHBORS 5
#define CONFIG_LWIP_ICMP 1
#define CONFIG_LWIP_MAX_RAW_PCBS 16
#define CONFIG_LWIP_SNTP_MAX_SERVERS 1
#define CONFIG_LWIP_SNTP_UPDATE_DELAY 3600000
#define CONFIG_LWIP_BRIDGEIF_MAX_PORTS 7
#define CONFIG_LWIP_ESP_LWIP_ASSERT 1
#define CONFIG_LWIP_HOOK_TCP_ISN_DEFAULT 1
#define CONFIG_LWIP_HOOK_IP6_ROUTE_NONE 1
#define CONFIG_LWIP_HOOK_ND6_GET_GW_NONE 1
#define CONFIG_LWIP_HOOK_NETCONN_EXT_RESOLVE_NONE 1
#define CONFIG_LWIP_HOOK_IP6_INPUT_NONE 1
#define CONFIG_MBEDTLS_INTERNAL_MEM_ALLOC 1
#define CONFIG_MBEDTLS_ASYMMETRIC_CONTENT_LEN 1
#define CONFIG_MBEDTLS_SSL_IN_CONTENT_LEN 16384
#define CONFIG_MBEDTLS_SSL_OUT_CONTENT_LEN 4096
#define CONFIG_MBEDTLS_SSL_KEEP_PEER_CERTIFICATE 1
#define CONFIG_MBEDTLS_CERTIFICATE_BUNDLE 1
#define CONFIG_MBEDTLS_CERTIFICATE_BUNDLE_DEFAULT_FULL 1
#define CONFIG_MBEDTLS_CERTIFICATE_BUNDLE_MAX_CERTS 200
#define CONFIG_MBEDTLS_HARDWARE_AES 1
#define CONFIG_MBEDTLS_AES_USE_INTERRUPT 1
#define CONFIG_MBEDTLS_HARDWARE_MPI 1
#define CONFIG_MBEDTLS_MPI_USE_INTERRUPT 1
#define CONFIG_MBEDTLS_HARDWARE_SHA 1
#define CONFIG_MBEDTLS_ROM_MD5 1
#define CONFIG_MBEDTLS_HAVE_TIME 1
#define CONFIG_MBEDTLS_ECDSA_DETERMINISTIC 1
#define CONFIG_MBEDTLS_SHA512_C 1
#define CONFIG_MBEDTLS_TLS_SERVER_AND_CLIENT 1
#define CONFIG_MBEDTLS_TLS_SERVER 1
#define CONFIG_MBEDTLS_TLS_CLIENT 1
#define CONFIG_MBEDTLS_TLS_ENABLED 1
#define CONFIG_MBEDTLS_KEY_EXCHANGE_RSA 1
#define CONFIG_MBEDTLS_KEY_EXCHANGE_ELLIPTIC_CURVE 1
#define CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_RSA 1
#define CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA 1
#define CONFIG_MBEDTLS_KEY_EXCHANGE_ECDH_ECDSA 1
#define CONFIG_MBEDTLS_KEY_EXCHANGE_ECDH_RSA 1
#define CONFIG_MBEDTLS_SSL_RENEGOTIATION 1
#define CONFIG_MBEDTLS_SSL_PROTO_TLS1_2 1
#define CONFIG_MBEDTLS_SSL_ALPN 1
#define CONFIG_MBEDTLS_CLIENT_SSL_SESSION_TICKETS 1
#define CONFIG_MBEDTLS_SERVER_SSL_SESSION_TICKETS 1
#define CONFIG_MBEDTLS_AES_C 1
#define CONFIG_MBEDTLS_CCM_C 1
#define CONFIG_MBEDTLS_GCM_C 1
#define CONFIG_MBEDTLS_PEM_PARSE_C 1
#define CONFIG_MBEDTLS_PEM_WRITE_C 1
#define CONFIG_MBEDTLS_X509_CRL_PARSE_C 1
#define CONFIG_MBEDTLS_X509_CSR_PARSE_C 1
#define CONFIG_MBEDTLS_ECP_C 1
#define CONFIG_MBEDTLS_ECDH_C 1
#define CONFIG_MBEDTLS_ECDSA_C 1
#define CONFIG_MBEDTLS_ECP_DP_SECP192R1_ENABLED 1
#define CONFIG_MBEDTLS_ECP_DP_SECP224R1_ENABLED 1
#define CONFIG_MBEDTLS_ECP_DP_SECP256R1_ENABLED 1
#define CONFIG_MBEDTLS_ECP_DP_SECP384R1_ENABLED 1
#define CONFIG_MBEDTLS_ECP_DP_SECP521R1_ENABLED 1
#define CONFIG_MBEDTLS_ECP_DP_SECP192K1_ENABLED 1
#define CONFIG_MBEDTLS_ECP_DP_SECP224K1_ENABLED 1
#define CONFIG_MBEDTLS_ECP_DP_SECP256K1_ENABLED 1
#define CONFIG_MBEDTLS_ECP_DP_BP256R1_ENABLED 1
#define CONFIG_MBEDTLS_ECP_DP_BP384R1_ENABLED 1
#define CONFIG_MBEDTLS_ECP_DP_BP512R1_ENABLED 1
#define CONFIG_MBEDTLS_ECP_DP_CURVE25519_ENABLED 1
#define CONFIG_MBEDTLS_ECP_NIST_OPTIM 1
#define CONFIG_MQTT_PROTOCOL_311 1
#define CONFIG_MQTT_TRANSPORT_SSL 1
#define CONFIG_MQTT_TRANSPORT_WEBSOCKET 1
#define CONFIG_MQTT_TRANSPORT_WEBSOCKET_SECURE 1
#define CONFIG_NEWLIB_STDOUT_LINE_ENDING_CRLF 1
#define CONFIG_NEWLIB_STDIN_LINE_ENDING_CR 1
#define CONFIG_NEWLIB_TIME_SYSCALL_USE_RTC_HRT 1
#define CONFIG_ESP_PROTOCOMM_SUPPORT_SECURITY_VERSION_0 1
#define CONFIG_ESP_PROTOCOMM_SUPPORT_SECURITY_VERSION_1 1
#define CONFIG_ESP_PROTOCOMM_SUPPORT_SECURITY_VERSION_2 1
#define CONFIG_PTHREAD_TASK_PRIO_DEFAULT 5
#define CONFIG_PTHREAD_TASK_STACK_SIZE_DEFAULT 3072
#define CONFIG_PTHREAD_STACK_MIN 768
#define CONFIG_PTHREAD_DEFAULT_CORE_NO_AFFINITY 1
#define CONFIG_PTHREAD_TASK_CORE_DEFAULT -1
#define CONFIG_PTHREAD_TASK_NAME_DEFAULT "pthread"
#define CONFIG_SPI_FLASH_ROM_DRIVER_PATCH 1
#define CONFIG_SPI_FLASH_HAS_ROM_IMPL 1
#define CONFIG_SPI_FLASH_DANGEROUS_WRITE_ABORTS 1
#define CONFIG_SPI_FLASH_YIELD_DURING_ERASE 1
#define CONFIG_SPI_FLASH_ERASE_YIELD_DURATION_MS 20
#define CONFIG_SPI_FLASH_ERASE_YIELD_TICKS 1
#define CONFIG_SPI_FLASH_WRITE_CHUNK_SIZE 8192
#define CONFIG_SPI_FLASH_BROWNOUT_RESET_XMC 1
#define CONFIG_SPI_FLASH_BROWNOUT_RESET 1
#define CONFIG_SPI_FLASH_SUPPORT_ISSI_CHIP 1
#define CONFIG_SPI_FLASH_SUPPORT_MXIC_CHIP 1
#define CONFIG_SPI_FLASH_SUPPORT_GD_CHIP 1
#define CONFIG_SPI_FLASH_SUPPORT_WINBOND_CHIP 1
#define CONFIG_SPI_FLASH_SUPPORT_BOYA_CHIP 1
#define CONFIG_SPI_FLASH_SUPPORT_TH_CHIP 1
#define CONFIG_SPI_FLASH_SUPPORT_MXIC_OPI_CHIP 1
#define CONFIG_SPI_FLASH_ENABLE_ENCRYPTED_READ_WRITE 1
#define CONFIG_SPIFFS_MAX_PARTITIONS 3
#define CONFIG_SPIFFS_CACHE 1
#define CONFIG_SPIFFS_CACHE_WR 1
#define CONFIG_SPIFFS_PAGE_CHECK 1
#define CONFIG_SPIFFS_GC_MAX_RUNS 10
#define CONFIG_SPIFFS_PAGE_SIZE 256
#define CONFIG_SPIFFS_OBJ_NAME_LEN 32
#define CONFIG_SPIFFS_USE_MAGIC 1
#define CONFIG_SPIFFS_USE_MAGIC_LENGTH 1
#define CONFIG_SPIFFS_META_LENGTH 4
#define CONFIG_SPIFFS_USE_MTIME 1
#define CONFIG_WS_TRANSPORT 1
#define CONFIG_WS_BUFFER_SIZE 1024
#define CONFIG_UNITY_ENABLE_FLOAT 1
#define CONFIG_UNITY_ENABLE_DOUBLE 1
#define CONFIG_UNITY_ENABLE_IDF_TEST_RUNNER 1
#define CONFIG_USB_OTG_SUPPORTED 1
#define CONFIG_USB_HOST_CONTROL_TRANSFER_MAX_SIZE 256
#define CONFIG_USB_HOST_HW_BUFFER_BIAS_BALANCED 1
#define CONFIG_VFS_SUPPORT_IO 1
#define CONFIG_VFS_SUPPORT_DIR 1
#define CONFIG_VFS_SUPPORT_SELECT 1
#define CONFIG_VFS_SUPPRESS_SELECT_DEBUG_OUTPUT 1
#define CONFIG_VFS_SUPPORT_TERMIOS 1
#define CONFIG_VFS_SEMIHOSTFS_MAX_MOUNT_POINTS 1
#define CONFIG_WL_SECTOR_SIZE_4096 1
#define CONFIG_WL_SECTOR_SIZE 4096
#define CONFIG_WIFI_PROV_SCAN_MAX_ENTRIES 16
#define CONFIG_WIFI_PROV_AUTOSTOP_TIMEOUT 30
#define CONFIG_WIFI_PROV_BLE_FORCE_ENCRYPTION 1
#define CONFIG_WPA_MBEDTLS_CRYPTO 1
#define CONFIG_WPA_MBEDTLS_TLS_CLIENT 1
#define CONFIG_GPIO_AW9523B_P0_PUSH_PULL 1
#define CONFIG_GPIO_AW9523B_USE_LED 1
#define CONFIG_AW9523b_LED_CURR_1_4 1
#define CONFIG_GPIO_AW9523B_LED_NUM 3
#define CONFIG_LV_USE_GUI_DESKTOP 1
#define CONFIG_LV_DESKTOP_ICON_NUM_VER 4
#define CONFIG_LV_DESKTOP_ICON_NUM_HOR 4
#define CONFIG_LV_DESKTOP_ICON_SIZE 100
#define CONFIG_LV_DESKTOP_ICON_TITLE_FONT "&font_lanting16"
#define CONFIG_LV_GUI_HEAD_HEIGHT 40
#define CONFIG_GUI_USE_MUSIC 1
#define CONFIG_LV_USE_GUI_CALC 1
#define CONFIG_LV_USE_GUI_FILE_EXPLORER 1
#define CONFIG_LV_GUI_FILE_EXPLORER_HOME_DIR "S:/littlefs"
#define CONFIG_LV_USE_ICON_12306 1
#define CONFIG_LV_USE_ICON_ALBUM 1
#define CONFIG_LV_USE_ICON_ALIBABA 1
#define CONFIG_LV_USE_ICON_ASSISTANCE 1
#define CONFIG_LV_USE_ICON_BAIDUMAP 1
#define CONFIG_LV_USE_ICON_BANKABC 1
#define CONFIG_LV_USE_ICON_BANKPS 1
#define CONFIG_LV_USE_ICON_BC 1
#define CONFIG_LV_USE_ICON_BEIBEI 1
#define CONFIG_LV_USE_ICON_BIGBANG 1
#define CONFIG_LV_USE_ICON_BILIBILI 1
#define CONFIG_LV_USE_ICON_BOC 1
#define CONFIG_LV_USE_ICON_BROWSER 1
#define CONFIG_LV_USE_ICON_BUGREPORT 1
#define CONFIG_LV_USE_ICON_CAINIAO 1
#define CONFIG_LV_USE_ICON_CALC 1
#define CONFIG_LV_USE_ICON_CALENDOR 1
#define CONFIG_LV_USE_ICON_CAMERA 1
#define CONFIG_LV_USE_ICON_CCB 1
#define CONFIG_LV_USE_ICON_CLOCK 1
#define CONFIG_LV_USE_ICON_CMB 1
#define CONFIG_LV_USE_ICON_COMPASS 1
#define CONFIG_LV_USE_ICON_CRH 1
#define CONFIG_LV_USE_ICON_DANGDANG 1
#define CONFIG_LV_USE_ICON_DIDI 1
#define CONFIG_LV_USE_ICON_EMAIL 1
#define CONFIG_LV_USE_ICON_FILEMANAGER 1
#define CONFIG_LV_USE_ICON_GOOGLEMAP 1
#define CONFIG_LV_USE_ICON_HAIGOU 1
#define CONFIG_LV_USE_ICON_HOMELINK 1
#define CONFIG_LV_USE_ICON_ICBC 1
#define CONFIG_LV_USE_ICON_IDEA 1
#define CONFIG_LV_USE_ICON_JD 1
#define CONFIG_LV_USE_ICON_MEITUAN 1
#define CONFIG_LV_USE_ICON_MESSAGE 1
#define CONFIG_LV_USE_ICON_MOGUJIE 1
#define CONFIG_LV_USE_ICON_MUSIC 1
#define CONFIG_LV_USE_ICON_NFZM 1
#define CONFIG_LV_USE_ICON_NOTE 1
#define CONFIG_LV_USE_ICON_ONESTEP 1
#define CONFIG_LV_USE_ICON_PHONE 1
#define CONFIG_LV_USE_ICON_QQ 1
#define CONFIG_LV_USE_ICON_QUNAR 1
#define CONFIG_LV_USE_ICON_REC 1
#define CONFIG_LV_USE_ICON_SEARCH 1
#define CONFIG_LV_USE_ICON_SETUP 1
#define CONFIG_LV_USE_ICON_SHUNFENG 1
#define CONFIG_LV_USE_ICON_SMARTISANMALL 1
#define CONFIG_LV_USE_ICON_SZZC 1
#define CONFIG_LV_USE_ICON_TAOBAO 1
#define CONFIG_LV_USE_ICON_TMALL 1
#define CONFIG_LV_USE_ICON_UMBRELLA 1
#define CONFIG_LV_USE_ICON_UNIQ 1
#define CONFIG_LV_USE_ICON_WALLET 1
#define CONFIG_LV_USE_ICON_WEATHER 1
#define CONFIG_LV_USE_ICON_WECHAT 1
#define CONFIG_LV_USE_ICON_WRITOR 1
#define CONFIG_LV_USE_100ASK_CALC 1
#define CONFIG_LV_100ASK_CALC_EXPR_LEN 128
#define CONFIG_LV_100ASK_CALC_MAX_NUM_LEN 5
#define CONFIG_LV_USE_FILE_EXPLORER 1
#define CONFIG_LV_FILE_EXPLORER_QUICK_ACCESS 1
#define CONFIG_LV_FILE_EXPLORER_PATH_MAX_LEN 64
#define CONFIG_LV_USE_LIB_CALC 1
#define CONFIG_LITTLEFS_MAX_PARTITIONS 1
#define CONFIG_LITTLEFS_PAGE_SIZE 256
#define CONFIG_LITTLEFS_OBJ_NAME_LEN 64
#define CONFIG_LITTLEFS_READ_SIZE 32
#define CONFIG_LITTLEFS_WRITE_SIZE 32
#define CONFIG_LITTLEFS_LOOKAHEAD_SIZE 128
#define CONFIG_LITTLEFS_CACHE_SIZE 512
#define CONFIG_LITTLEFS_BLOCK_CYCLES 512
#define CONFIG_LITTLEFS_USE_MTIME 1
#define CONFIG_LITTLEFS_MTIME_USE_SECONDS 1
#define CONFIG_LITTLEFS_SPIFFS_COMPAT 1
#define CONFIG_BSP_ERROR_CHECK 1
#define CONFIG_BSP_I2C_NUM 1
#define CONFIG_BSP_I2C_FAST_MODE 1
#define CONFIG_BSP_I2C_CLK_SPEED_HZ 400000
#define CONFIG_BSP_LCD_HSD040BPN1_A00_480_480 1
#define CONFIG_BSP_LCD_RGB_DOUBLE_BUFFER 1
#define CONFIG_BSP_DISPLAY_LVGL_TASK_PRIORITY 2
#define CONFIG_BSP_DISPLAY_LVGL_TICK 5
#define CONFIG_BSP_DISPLAY_LVGL_PSRAM 1
#define CONFIG_BSP_DISPLAY_LVGL_BUF_HEIGHT 480
#define CONFIG_BSP_I2S_NUM 1
#define CONFIG_ESP_LCD_TOUCH_MAX_POINTS 5
#define CONFIG_ESP_LCD_TOUCH_MAX_BUTTONS 1
#define CONFIG_LV_CONF_SKIP 1
#define CONFIG_LV_COLOR_DEPTH_16 1
#define CONFIG_LV_COLOR_DEPTH 16
#define CONFIG_LV_COLOR_MIX_ROUND_OFS 128
#define CONFIG_LV_COLOR_CHROMA_KEY_HEX 0x00FF00
#define CONFIG_LV_MEM_CUSTOM 1
#define CONFIG_LV_MEM_CUSTOM_INCLUDE "stdlib.h"
#define CONFIG_LV_MEM_BUF_MAX_NUM 64
#define CONFIG_LV_MEMCPY_MEMSET_STD 1
#define CONFIG_LV_DISP_DEF_REFR_PERIOD 30
#define CONFIG_LV_INDEV_DEF_READ_PERIOD 30
#define CONFIG_LV_DPI_DEF 130
#define CONFIG_LV_DRAW_COMPLEX 1
#define CONFIG_LV_SHADOW_CACHE_SIZE 0
#define CONFIG_LV_CIRCLE_CACHE_SIZE 4
#define CONFIG_LV_LAYER_SIMPLE_BUF_SIZE 24576
#define CONFIG_LV_IMG_CACHE_DEF_SIZE 3
#define CONFIG_LV_GRADIENT_MAX_STOPS 2
#define CONFIG_LV_GRAD_CACHE_DEF_SIZE 0
#define CONFIG_LV_DISP_ROT_MAX_BUF 10240
#define CONFIG_LV_USE_LOG 1
#define CONFIG_LV_LOG_LEVEL_USER 1
#define CONFIG_LV_LOG_LEVEL 4
#define CONFIG_LV_LOG_PRINTF 1
#define CONFIG_LV_LOG_TRACE_MEM 1
#define CONFIG_LV_LOG_TRACE_TIMER 1
#define CONFIG_LV_LOG_TRACE_INDEV 1
#define CONFIG_LV_LOG_TRACE_DISP_REFR 1
#define CONFIG_LV_LOG_TRACE_EVENT 1
#define CONFIG_LV_LOG_TRACE_OBJ_CREATE 1
#define CONFIG_LV_LOG_TRACE_LAYOUT 1
#define CONFIG_LV_LOG_TRACE_ANIM 1
#define CONFIG_LV_USE_ASSERT_NULL 1
#define CONFIG_LV_USE_ASSERT_MALLOC 1
#define CONFIG_LV_ASSERT_HANDLER_INCLUDE "assert.h"
#define CONFIG_LV_USE_PERF_MONITOR 1
#define CONFIG_LV_PERF_MONITOR_ALIGN_BOTTOM_RIGHT 1
#define CONFIG_LV_USE_USER_DATA 1
#define CONFIG_LV_ATTRIBUTE_MEM_ALIGN_SIZE 1
#define CONFIG_LV_FONT_MONTSERRAT_12 1
#define CONFIG_LV_FONT_MONTSERRAT_14 1
#define CONFIG_LV_FONT_MONTSERRAT_16 1
#define CONFIG_LV_FONT_MONTSERRAT_18 1
#define CONFIG_LV_FONT_MONTSERRAT_20 1
#define CONFIG_LV_FONT_MONTSERRAT_24 1
#define CONFIG_LV_FONT_DEFAULT_MONTSERRAT_14 1
#define CONFIG_LV_USE_FONT_PLACEHOLDER 1
#define CONFIG_LV_TXT_ENC_UTF8 1
#define CONFIG_LV_TXT_BREAK_CHARS " ,.;:-_"
#define CONFIG_LV_TXT_LINE_BREAK_LONG_LEN 0
#define CONFIG_LV_TXT_COLOR_CMD "#"
#define CONFIG_LV_USE_ARC 1
#define CONFIG_LV_USE_BAR 1
#define CONFIG_LV_USE_BTN 1
#define CONFIG_LV_USE_BTNMATRIX 1
#define CONFIG_LV_USE_CANVAS 1
#define CONFIG_LV_USE_CHECKBOX 1
#define CONFIG_LV_USE_DROPDOWN 1
#define CONFIG_LV_USE_IMG 1
#define CONFIG_LV_USE_LABEL 1
#define CONFIG_LV_LABEL_TEXT_SELECTION 1
#define CONFIG_LV_LABEL_LONG_TXT_HINT 1
#define CONFIG_LV_USE_LINE 1
#define CONFIG_LV_USE_ROLLER 1
#define CONFIG_LV_ROLLER_INF_PAGES 7
#define CONFIG_LV_USE_SLIDER 1
#define CONFIG_LV_USE_SWITCH 1
#define CONFIG_LV_USE_TEXTAREA 1
#define CONFIG_LV_TEXTAREA_DEF_PWD_SHOW_TIME 1500
#define CONFIG_LV_USE_TABLE 1
#define CONFIG_LV_USE_ANIMIMG 1
#define CONFIG_LV_USE_CALENDAR 1
#define CONFIG_LV_USE_CALENDAR_HEADER_ARROW 1
#define CONFIG_LV_USE_CALENDAR_HEADER_DROPDOWN 1
#define CONFIG_LV_USE_CHART 1
#define CONFIG_LV_USE_COLORWHEEL 1
#define CONFIG_LV_USE_IMGBTN 1
#define CONFIG_LV_USE_KEYBOARD 1
#define CONFIG_LV_USE_LED 1
#define CONFIG_LV_USE_LIST 1
#define CONFIG_LV_USE_MENU 1
#define CONFIG_LV_USE_METER 1
#define CONFIG_LV_USE_MSGBOX 1
#define CONFIG_LV_USE_SPAN 1
#define CONFIG_LV_SPAN_SNIPPET_STACK_SIZE 64
#define CONFIG_LV_USE_SPINBOX 1
#define CONFIG_LV_USE_SPINNER 1
#define CONFIG_LV_USE_TABVIEW 1
#define CONFIG_LV_USE_TILEVIEW 1
#define CONFIG_LV_USE_WIN 1
#define CONFIG_LV_USE_THEME_DEFAULT 1
#define CONFIG_LV_THEME_DEFAULT_GROW 1
#define CONFIG_LV_THEME_DEFAULT_TRANSITION_TIME 80
#define CONFIG_LV_USE_THEME_BASIC 1
#define CONFIG_LV_USE_FLEX 1
#define CONFIG_LV_USE_GRID 1
#define CONFIG_LV_USE_PNG 1
#define CONFIG_LV_USE_BMP 1
#define CONFIG_LV_USE_SJPG 1
#define CONFIG_LV_USE_GIF 1
#define CONFIG_LV_USE_SNAPSHOT 1
#define CONFIG_LV_BUILD_EXAMPLES 1
#define CONFIG_LV_USE_DEMO_WIDGETS 1
#define CONFIG_LV_USE_DEMO_BENCHMARK 1
#define CONFIG_LV_USE_DEMO_STRESS 1
#define CONFIG_LV_USE_DEMO_MUSIC 1
#define CONFIG_LV_DEMO_MUSIC_AUTO_PLAY 1
/* List of deprecated options */
#define CONFIG_BROWNOUT_DET CONFIG_ESP_BROWNOUT_DET
#define CONFIG_BROWNOUT_DET_LVL CONFIG_ESP_BROWNOUT_DET_LVL
#define CONFIG_BROWNOUT_DET_LVL_SEL_7 CONFIG_ESP_BROWNOUT_DET_LVL_SEL_7
#define CONFIG_CONSOLE_UART_NUM CONFIG_ESP_CONSOLE_UART_NUM
#define CONFIG_ESP32S3_BROWNOUT_DET CONFIG_ESP_BROWNOUT_DET
#define CONFIG_ESP32S3_BROWNOUT_DET_LVL CONFIG_ESP_BROWNOUT_DET_LVL
#define CONFIG_ESP32S3_BROWNOUT_DET_LVL_SEL_7 CONFIG_ESP_BROWNOUT_DET_LVL_SEL_7
#define CONFIG_ESP32S3_DEBUG_OCDAWARE CONFIG_ESP_DEBUG_OCDAWARE
#define CONFIG_ESP32S3_DEEP_SLEEP_WAKEUP_DELAY CONFIG_ESP_SLEEP_DEEP_SLEEP_WAKEUP_DELAY
#define CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240 CONFIG_ESP_DEFAULT_CPU_FREQ_MHZ_240
#define CONFIG_ESP32S3_DEFAULT_CPU_FREQ_MHZ CONFIG_ESP_DEFAULT_CPU_FREQ_MHZ
#define CONFIG_ESP32S3_RTC_CLK_CAL_CYCLES CONFIG_RTC_CLK_CAL_CYCLES
#define CONFIG_ESP32S3_RTC_CLK_SRC_INT_RC CONFIG_RTC_CLK_SRC_INT_RC
#define CONFIG_ESP32S3_SPIRAM_SUPPORT CONFIG_SPIRAM
#define CONFIG_ESP32S3_TIME_SYSCALL_USE_RTC_FRC1 CONFIG_NEWLIB_TIME_SYSCALL_USE_RTC_HRT
#define CONFIG_ESP32S3_TIME_SYSCALL_USE_RTC_SYSTIMER CONFIG_NEWLIB_TIME_SYSCALL_USE_RTC_HRT
#define CONFIG_ESP32_APPTRACE_DEST_NONE CONFIG_APPTRACE_DEST_NONE
#define CONFIG_ESP32_APPTRACE_LOCK_ENABLE CONFIG_APPTRACE_LOCK_ENABLE
#define CONFIG_ESP32_DEFAULT_PTHREAD_CORE_NO_AFFINITY CONFIG_PTHREAD_DEFAULT_CORE_NO_AFFINITY
#define CONFIG_ESP32_ENABLE_COREDUMP_TO_NONE CONFIG_ESP_COREDUMP_ENABLE_TO_NONE
#define CONFIG_ESP32_PHY_CALIBRATION_AND_DATA_STORAGE CONFIG_ESP_PHY_CALIBRATION_AND_DATA_STORAGE
#define CONFIG_ESP32_PHY_MAX_TX_POWER CONFIG_ESP_PHY_MAX_TX_POWER
#define CONFIG_ESP32_PHY_MAX_WIFI_TX_POWER CONFIG_ESP_PHY_MAX_WIFI_TX_POWER
#define CONFIG_ESP32_PTHREAD_STACK_MIN CONFIG_PTHREAD_STACK_MIN
#define CONFIG_ESP32_PTHREAD_TASK_CORE_DEFAULT CONFIG_PTHREAD_TASK_CORE_DEFAULT
#define CONFIG_ESP32_PTHREAD_TASK_NAME_DEFAULT CONFIG_PTHREAD_TASK_NAME_DEFAULT
#define CONFIG_ESP32_PTHREAD_TASK_PRIO_DEFAULT CONFIG_PTHREAD_TASK_PRIO_DEFAULT
#define CONFIG_ESP32_PTHREAD_TASK_STACK_SIZE_DEFAULT CONFIG_PTHREAD_TASK_STACK_SIZE_DEFAULT
#define CONFIG_ESP32_REDUCE_PHY_TX_POWER CONFIG_ESP_PHY_REDUCE_TX_POWER
#define CONFIG_ESP_GRATUITOUS_ARP CONFIG_LWIP_ESP_GRATUITOUS_ARP
#define CONFIG_ESP_SYSTEM_PM_POWER_DOWN_CPU CONFIG_PM_POWER_DOWN_CPU_IN_LIGHT_SLEEP
#define CONFIG_FLASHMODE_DIO CONFIG_ESPTOOLPY_FLASHMODE_DIO
#define CONFIG_GARP_TMR_INTERVAL CONFIG_LWIP_GARP_TMR_INTERVAL
#define CONFIG_IPC_TASK_STACK_SIZE CONFIG_ESP_IPC_TASK_STACK_SIZE
#define CONFIG_LOG_BOOTLOADER_LEVEL CONFIG_BOOTLOADER_LOG_LEVEL
#define CONFIG_LOG_BOOTLOADER_LEVEL_INFO CONFIG_BOOTLOADER_LOG_LEVEL_INFO
#define CONFIG_MAIN_TASK_STACK_SIZE CONFIG_ESP_MAIN_TASK_STACK_SIZE
#define CONFIG_MONITOR_BAUD CONFIG_ESPTOOLPY_MONITOR_BAUD
#define CONFIG_OPTIMIZATION_ASSERTIONS_ENABLED CONFIG_COMPILER_OPTIMIZATION_ASSERTIONS_ENABLE
#define CONFIG_OPTIMIZATION_ASSERTION_LEVEL CONFIG_COMPILER_OPTIMIZATION_ASSERTION_LEVEL
#define CONFIG_POST_EVENTS_FROM_IRAM_ISR CONFIG_ESP_EVENT_POST_FROM_IRAM_ISR
#define CONFIG_POST_EVENTS_FROM_ISR CONFIG_ESP_EVENT_POST_FROM_ISR
#define CONFIG_REDUCE_PHY_TX_POWER CONFIG_ESP_PHY_REDUCE_TX_POWER
#define CONFIG_SEMIHOSTFS_MAX_MOUNT_POINTS CONFIG_VFS_SEMIHOSTFS_MAX_MOUNT_POINTS
#define CONFIG_SPI_FLASH_WRITING_DANGEROUS_REGIONS_ABORTS CONFIG_SPI_FLASH_DANGEROUS_WRITE_ABORTS
#define CONFIG_STACK_CHECK_NONE CONFIG_COMPILER_STACK_CHECK_MODE_NONE
#define CONFIG_SUPPORT_TERMIOS CONFIG_VFS_SUPPORT_TERMIOS
#define CONFIG_SUPPRESS_SELECT_DEBUG_OUTPUT CONFIG_VFS_SUPPRESS_SELECT_DEBUG_OUTPUT
#define CONFIG_SYSTEM_EVENT_QUEUE_SIZE CONFIG_ESP_SYSTEM_EVENT_QUEUE_SIZE
#define CONFIG_SYSTEM_EVENT_TASK_STACK_SIZE CONFIG_ESP_SYSTEM_EVENT_TASK_STACK_SIZE
#define CONFIG_TCPIP_RECVMBOX_SIZE CONFIG_LWIP_TCPIP_RECVMBOX_SIZE
#define CONFIG_TCPIP_TASK_AFFINITY CONFIG_LWIP_TCPIP_TASK_AFFINITY
#define CONFIG_TCPIP_TASK_AFFINITY_NO_AFFINITY CONFIG_LWIP_TCPIP_TASK_AFFINITY_NO_AFFINITY
#define CONFIG_TCPIP_TASK_STACK_SIZE CONFIG_LWIP_TCPIP_TASK_STACK_SIZE
#define CONFIG_TCP_MAXRTX CONFIG_LWIP_TCP_MAXRTX
#define CONFIG_TCP_MSL CONFIG_LWIP_TCP_MSL
#define CONFIG_TCP_MSS CONFIG_LWIP_TCP_MSS
#define CONFIG_TCP_OVERSIZE_MSS CONFIG_LWIP_TCP_OVERSIZE_MSS
#define CONFIG_TCP_QUEUE_OOSEQ CONFIG_LWIP_TCP_QUEUE_OOSEQ
#define CONFIG_TCP_RECVMBOX_SIZE CONFIG_LWIP_TCP_RECVMBOX_SIZE
#define CONFIG_TCP_SND_BUF_DEFAULT CONFIG_LWIP_TCP_SND_BUF_DEFAULT
#define CONFIG_TCP_SYNMAXRTX CONFIG_LWIP_TCP_SYNMAXRTX
#define CONFIG_TCP_WND_DEFAULT CONFIG_LWIP_TCP_WND_DEFAULT
#define CONFIG_TIMER_QUEUE_LENGTH CONFIG_FREERTOS_TIMER_QUEUE_LENGTH
#define CONFIG_TIMER_TASK_PRIORITY CONFIG_FREERTOS_TIMER_TASK_PRIORITY
#define CONFIG_TIMER_TASK_STACK_DEPTH CONFIG_FREERTOS_TIMER_TASK_STACK_DEPTH
#define CONFIG_TIMER_TASK_STACK_SIZE CONFIG_ESP_TIMER_TASK_STACK_SIZE
#define CONFIG_UDP_RECVMBOX_SIZE CONFIG_LWIP_UDP_RECVMBOX_SIZE
文件系统导致显示错位
Re: 文件系统导致显示错位
原因:
该问题通常是因为 RGB 需要连续数据输出,当 Flash 或其他应用程序禁用或抢占 PSRAM 带宽时,数据传输将无法跟上 RGB 的时钟速度,从而导致永久的屏幕漂移。
解决方法:
请先尝试文档中的方法优化工程的配置并尽量降低 PCLK,如果需要使用 Wifi 和连续写 Flash 的操作,请使用 "PSRAM XIP" + "RGB Bounce buffer" 的方法,开启步骤如下:
确认 IDF 版本为较新(> 2022.12.12)的 release/v5.0 及以上,因为旧版本不支持 "PSRAM XIP" 的功能
确认 PSRAM 配置里面是否能开启 SPIRAM_FETCH_INSTRUCTIONS 和 SPIRAM_RODATA 这两项(如果 rodata 段数据过大,会导致 PSRAM 内存不够)
确认内存(SRAM)是否有余量,大概需要占用 10 * screen_width * 4 字节
需要将 Data cache line size 设置为 64 Byte(可设置 Data cache line size 为 32KB 以节省内存)
如以上均符合条件,那么就可以参考文档修改 RGB 驱动(RGB 驱动里加上一行代码 .bounce_buffer_size_px = 10 * 屏幕宽度)
如操作 Wifi 仍存在屏幕漂移问题,可以尝试关闭 PSRAM 里 CONFIG_SPIRAM_TRY_ALLOCATE_WIFI_LWIP 一项(会占用较大 SRAM)
开启后带来的影响:
CPU 使用率升高
可能会造成中断看门狗复位
会造成较大内存开销
解决方法:
开启后带来的影响:
CPU 使用率升高
可能会造成中断看门狗复位
会造成较大内存开销
