ESP Insight not recognized by Compiler
Vaibhav Singh
Postby Vaibhav Singh » Tue Mar 14, 2023 11:40 am
Hello All,
I am trying to integrate the ESP Insight feature into one of my projects but apparently whenever I am building the project it never recognizes the Insight header file esp_insight.h file I have made all the necessary addition in my root cmake file and my env variable and downloaded the necessary repo but I am unable to build my code
Code: Untitled.cmake Select all
[code]cmake_minimum_required(VERSION 3.16)
if(DEFINED ENV{INSIGHTS_PATH})
set(INSIGHTS_PATH $ENV{INSIGHTS_PATH})
else()
set(INSIGHTS_PATH ${CMAKE_CURRENT_LIST_DIR}/../..)
endif(DEFINED ENV{INSIGHTS_PATH})
# Add RainMaker components
set(EXTRA_COMPONENT_DIRS ${INSIGHTS_PATH}/components ${INSIGHTS_PATH}/examples/common)
set(EXTRA_COMPONENT_DIRS $ENV{IDF_PATH}/examples/protocols/modbus/mb_example_common)
include($ENV{IDF_PATH}/tools/cmake/project.cmake)
project(Feb_RS485)[/code]
Can anyone Help me in identifying the problems ??
Screenshot (31).png (9.92 KiB) Viewed 1458 times
ESP_alisitsyn
Contact:
Re: ESP Insight not recognized by Compiler
Postby ESP_alisitsyn » Thu Mar 16, 2023 8:38 am
Hello, @Vaibhav Singh,
In your cmake file you added the mb_example_common incorrectly through EXTRA_COMPONENT_DIRS and the previous value set for RainMaker is overwritten. Please change the last line as below:
......  the above lines of cmake file
list(APPEND EXTRA_COMPONENT_DIRS "$ENV{IDF_PATH}/examples/protocols/modbus/mb_example_common")
project(Feb_RS485)
[/code]
Users browsing this forum: Bing [Bot], ChatGPT-User, Qwantbot, RathiSonika and 3 guests
