Hey Guys,
I am very new to this. I have 6 ESP32s eash with a servo. I want each servo to move to 2 positions only. Position 1 (HOME) and POSITION 2 (AWAY) and i want them all to move after send ing one command to all - either way.
Is there a way to do this? blynk or from another ESP32 or 8266.
Thanks,
Sean
6x ESP32 each with Servo
Re: 6x ESP32 each with Servo
You could use this LED light example and tutorial, based on Rainmaker, which will give you the firmware, the phone app and the cloud services in a very easy implementation. However, I am not familiar with how servos are controlled, if it's ON/OFF then thy job is done, otherwise it will require you to write a piece of code. Here's the link to the right place. It's
https://rainmaker.espressif.com/docs/get-started.html
Users browsing this forum: Google [Bot] and 90 guests
