ESP32 / Arduino IDE problem - ModuleNotFoundError: No module named 'serial'
DronePilot
Postby DronePilot » Mon Mar 27, 2023 10:49 am
Hello forum!
I am trying to verify sample / example code for ESP32 and I got error every time:
File "/home/cc/.arduino15/packages/esp32/tools/esptool_py/4.5.1/esptool.py", line 31, in <module>
import esptool
File "/home/cc/.arduino15/packages/esp32/tools/esptool_py/4.5.1/esptool/__init__.py", line 41, in <module>
from esptool.cmds import (
File "/home/cc/.arduino15/packages/esp32/tools/esptool_py/4.5.1/esptool/cmds.py", line 14, in <module>
from .bin_image import ELFFile, ImageSegment, LoadFirmwareImage
File "/home/cc/.arduino15/packages/esp32/tools/esptool_py/4.5.1/esptool/bin_image.py", line 14, in <module>
from .loader import ESPLoader
File "/home/cc/.arduino15/packages/esp32/tools/esptool_py/4.5.1/esptool/loader.py", line 30, in <module>
import serial
exit status 1
Compilation error: exit status 1
I have installed pyserial with command:
python -m pip install pyserial
but this did not solve the problem
I am using Linux Ubuntu and Arduino IDE.
Thanks for help!
corz.org
Contact:
Re: ESP32 / Arduino IDE problem - ModuleNotFoundError: No module named 'serial'
Postby corz.org » Tue Mar 28, 2023 3:31 am
What version of Python are you using?
Also, ensure you have the correct upload settings in your IDE.
NigelTwo
Postby NigelTwo » Wed Mar 29, 2023 1:23 am
With LinuxMint21.1 (Ubuntu derivative) I found that installing the deb package esptool fixed this.
DronePilot
Postby DronePilot » Tue Apr 11, 2023 9:20 am
Problem solved - I have installed Arduino IDE from "Ubuntu Software". Now IDE works good!
tempAccount123456
Postby tempAccount123456 » Sun Apr 16, 2023 6:46 am
lol for me i was messing around with my usergroups. I am part of dialout but sometimes in couldnt see USB0 when using ls /dev/tty*. Somehow i ended up adding myself to a group with root and then chmodding group perms for rw. Worked. But not safe. Whatever though. Its my personal machine lol
Users browsing this forum: Amazon [Bot], Qwantbot and 5 guests
