I am working on the ESP32-S2 and I would like to be able to stream radio from the internet. There are arduino libraries on the ESP32 but not for the ESP32-S2. They are not compatible, I have several errors during the compilation.
I don't use an mp3 codec, but just an amplifier in I2S MAX98360 in I2S.
Has anyone ever managed to do this on the ESP32-S2?
Here are exemple of errors I have with the library https://github.com/schreibfaul1/ESP32-audioI2S
error: 'I2S_MODE_DAC_BUILT_IN' was not declared in this scope
m_i2s_config.mode = (i2s_mode_t)(I2S_MODE_MASTER | I2S_MODE_TX | I2S_MODE_DAC_BUILT_IN );
error: 'i2s_set_dac_mode' was not declared in this scope
i2s_set_dac_mode(m_f_channelEnabled);
Sani300
ESP32-S2 Audio I2S library
Re: ESP32-S2 Audio I2S library
There are work in progress regarding the I2S support on Arduino.
https://github.com/espressif/arduino-esp32/pull/5304
You can track this PR to keep updated.
I just picked up a few S2 modules and the first thing I try to upload I get
I don't see any mention of this error on the page linked here.
Does anyone know if there is any progress here?
error: 'I2S_MODE_DAC_BUILT_IN' was not declared in this scopeDoes anyone know if there is any progress here?
What esp32 -s2 module do you have ? and what i2s library, does it support esp32-s2 ?
I get the same result on all three of my new S2 modules (Muse Lab WROVER (Saola compatible) board, VCC-GND Yo-ESP32-S2-MINI-2 (both dual USB boards) and a skinny WROOM ESP32-S2 with single built-in USB-C).
https://www.aliexpress.com/item/1005001403045642.html
https://www.aliexpress.com/item/1005004983811502.html (came with MicroPython installed)
https://www.aliexpress.com/item/1005004499308167.html ( ditto)
I'm using the built-in libraries. I imagine the relevant ones being..
I'm setting up i2S to output via the DAC, which runs fine on all the regular ESP32 chips I've tried..
It's only the final parameter it's getting upset about. When I rummage in the header files I see that the definition is conditional in the S2 headers..
I assumed the S2 variant's DAC was fully functional.
#include "driver/dac.h"
#include "driver/i2s.h"Code: Select all
i2s_driver_config_t i2s_config = {
.mode = (i2s_mode_t)(I2S_MODE_MASTER | I2S_MODE_TX | I2S_MODE_DAC_BUILT_IN),
.sample_rate = 10000000, // (updated dynamically)
.bits_per_sample = I2S_BITS_PER_SAMPLE_16BIT,
.channel_format = I2S_CHANNEL_FMT_RIGHT_LEFT,
.communication_format = I2S_COMM_FORMAT_STAND_MSB,
.intr_alloc_flags = 0,
.dma_buf_count = 2,
.dma_buf_len = 32, // updated dynamically
.use_apll = 0,
.tx_desc_auto_clear = false,
.fixed_mclk = 0,
.mclk_multiple = I2S_MCLK_MULTIPLE_DEFAULT, // Another parameter added to suppress compiler messages :roll:
.bits_per_chan = I2S_BITS_PER_CHAN_DEFAULT
};Code: Select all
#if SOC_I2S_SUPPORTS_DAC
//built-in DAC functions are only supported on I2S0 for ESP32 chip.
I2S_MODE_DAC_BUILT_IN = (0x1 << 4), /*!< Output I2S data to built-in DAC, no matter the data format is 16bit or 32 bit, the DAC module will only take the 8bits from MSB*/
#endif // SOC_I2S_SUPPORTS_DACWho is online
