ESP32-S3-WROOM-1 loses CDC serial port when starting SPI
mathijs
Postby mathijs » Mon May 15, 2023 7:04 pm
I've created a custom board using an ESP32-S3-WROOM-1 which is connected to a Wiznet W6100 chip over SPI. The ESP32S3 is connected to USB over pins 13/14 (GPIO19/GPIO20). I can flash the chip without problems.
The W6100 in SPI mode is connected to the following pins:
18 (GPIO10): chip select
19 (GPIO11): MOSI
20 (GPIO12): SCLK
21 (GPIO13): MISO
Every time I try to connect to the SPI device, the ESP32S3 loses its serial connection. Rebooting in the bootloader restores the connection. Changing the pins to input / output manually gives the same result.
Simplest version which crashes right after
Code: Untitled.c Select all
Serial.println("Setting VSPI_SCK"):
Code: main.cpp Select all
#include <Arduino.h>
#include <SPI.h>
#define VSPI_SCK 19
#define VSPI_MISO 21
#define VSPI_MOSI 20
#define VSPI_SS 18
void setup() {
Serial.begin(115200);
Serial.println("Starting");
Serial.println("Setting VSPI_SS");
pinMode(VSPI_SS, OUTPUT); //HSPI SS
Serial.println("Setting VSPI_SCK");
delay(1000);
pinMode(VSPI_SCK, OUTPUT); //HSPI SS
Serial.println("Setting VSPI_MISO");
delay(1000);
pinMode(VSPI_MISO, INPUT); //HSPI SS
Serial.println("Setting SS");
delay(1000);
pinMode(VSPI_MISO, OUTPUT); //HSPI SS
Serial.println("Init ethernet");
void loop() {}
My platformio project:
Code: platformio.ini Select all
[env:esp32-s3-custom]
platform = espressif32
board = custom_pcb
board_build.arduino.memory_type = dio_opi
framework = arduino
monitor_speed = 115200
build_flags =
-D PIO_FRAMEWORK_ARDUINO_ENABLE_CDC
-D USBCON
-DCORE_DEBUG_LEVEL=5
-DBOARD_HAS_PSRAM
-mfix-esp32-psram-cache-issue
lib_ldf_mode = deep+
lib_deps =
https://github.com/WIZnet-ArduinoEthernet/Ethernet.git
adafruit/Adafruit NeoPixel@^1.11.0
and the board definition:
Code: custom_pcb.json Select all
"build": {
"arduino": {
"ldscript": "esp32s3_out.ld",
"partitions": "default_8MB.csv",
"memory_type": "qio_opi"
"core": "esp32",
"extra_flags": [
"-DBOARD_HAS_PSRAM",
"-DARDUINO_USB_MODE=1",
"-DARDUINO_USB_CDC_ON_BOOT=1"
"f_cpu": "240000000L",
"f_flash": "80000000L",
"flash_mode": "qio",
"hwids": [
"0x303A",
"0x1001"
"mcu": "esp32s3",
"variant": "esp32s3"
"connectivity": [
"wifi"
"debug": {
"openocd_target": "esp32s3.cfg"
"frameworks": [
"arduino",
"espidf"
"name": "custom_pcb",
"upload": {
"flash_size": "8MB",
"maximum_ram_size": 327680,
"maximum_size": 16777216,
"use_1200bps_touch": true,
"wait_for_upload_port": true,
"require_upload_port": true,
"speed": 460800
"url": "https://www.google.nl",
"vendor": "ME"
Does anyone have a clue what could cause this?
Re: ESP32-S3-WROOM-1 loses CDC serial port when starting SPI
Postby Sprite » Tue May 16, 2023 8:31 am
pinMode and friends take the GPIO number, not the pin number. In other words, you're reconfiguring GPIO 19 and 20 and as such losing USB.
Users browsing this forum: Google [Bot] and 4 guests
