Hello everyone.
I have set up an http server at 192.168.4.1:80 and a tcp server at 192.168.4.1 listening on port 5000, how should I transfer the data from the tcp server to the web using the http server? Any suggestions?
There are about 2 ideas now, the first is to set up a tcp client on the http server to forward the data from the tcp server to the http server, the second is to do port data forwarding at the ip layer and forward the data on port 5000 directly to port 80, am I understanding this correctly? Is there a better way to do this?
Thanks.
transport messages between tcp server and http server
MicroController
Re: transport messages between tcp server and http server
What are you trying to do? I think you may not be aware of the differences between HTTP and TCP.forward the data on port 5000 directly to port 80
The ultimate goal is to use the same ip, port 80 for the webserver and port 5000 for the tcp server listening port. I need to display the incoming and outgoing data on port 5000 on the webserver.What are you trying to do? I think you may not be aware of the differences between HTTP and TCP.forward the data on port 5000 directly to port 80
MicroController
Ok, but
What do you mean by "display" the data "on the webserver"?
doesn't make sense.I need to display the incoming and outgoing data on port 5000 on the webserver.
Users browsing this forum: Baidu [Spider], Bytespider, DuckDuckGo [Bot], RathiSonika, trendictionbot and 7 guests
