TPL5110 & HT7833 & ESP32-C3-13 MCU combination problem
ogedik
Re: TPL5110 & HT7833 & ESP32-C3-13 MCU combination problem
Postby ogedik » Sun Jul 30, 2023 9:41 am
Are you using a DevkitC now? That has a bunch of stuff on it that also uses power; don't use that if you want to get the power usage of only the ESP32C3; use a module or the raw chip instead.
Hi ESP_Sprite,
Very good approach. You are exactly correct! I will try to use only ESP32C3 as you suggested. Then I will analyze and reply with my results. Thank you for your help :)
Additionally, independent from ESP32 issue, why there's a huge current difference on HT7833 between my readings and reference value on datasheet without any load? Does it make any sense?
I am in learning curve :) Thank you your patience.
Best regards,
Orkun Gedik
MicroController
Postby MicroController » Sun Jul 30, 2023 10:57 am
A 1K resistor will pass 3.3mA @ 3.3V, so if R4 and R5 are 1K each, together they will drain about 6.6mA. Not much of a difference while the ESP is active, but when it's in deep sleep R4+R5 will continue to draw 100x as much current as the sleeping ESP :)
MicroController
Postby MicroController » Sun Jul 30, 2023 11:22 am
I attached resistor between legs because of CAPS cannot drain its power as fast as enough to the circuit (time constant calculation). If I do not attach resistors, ESP do not really turn off and able to find enough power to continue its process,
C4: 2200 uF capacitor
This is a huge capacitor in this case; too big by a factor of 100-1000.
Also, the HT7833's dropout voltage is specified as 360-500mV, so input voltages below 3.3V+0.5V = 3.8V can cause issues; and its other specs are only given for Vin>=Vout+1V...
ogedik
Postby ogedik » Sun Jul 30, 2023 6:52 pm
Hi MicroController,
Thank you so much for your precious information with crystal clear explanations. I learned a lot by your feedbacks, too. Now, I feel more safe while making amphere calculation of my circuits. I am just curious about one thing that is there any kind of formula/calculation about how much uF capacitor required for ESP32 WiFi with 3.7 LiPo?
As far as I understand from your suggestion that ESP32 and HT7833 combination with 3.7v is not good enough.
Now I will setup a new circuit with raw ESP32 as ESP_Sprite suggested without resistors and make new calculation with your suggestions. Then share my analyze result here.
Thank you again :)
Best regards,
Orkun Gedik
ogedik
Postby ogedik » Tue Aug 08, 2023 12:40 pm
I redesigned my circuit with ESP-C3-13 module according to your suggestions. My readings are 17 uA now in deep sleep which is perfect. ESP_Sprite and MicroController both you are my hero!
Thank you for your great insights.
Best regards,
Orkun Gedik
Users browsing this forum: Amazon [Bot], ChatGPT-User, PetalBot and 3 guests
