Is there a way to display how long the compilation took?
One way I could thinks about is use idf.preBuildTask and idf.postBuildTask to record start and end time. Is there better way? Or idf.py already have build-in functions I didn't found
thanks.
Can I display how long the build task takes in vscode extension?
policeman0077
Re: Can I display how long the build task takes in vscode extension?
Maybe you can try to use some additional option of ninja-build. In your <project-dir>/.vscode/settings.json add:
"idf.ninjaArgs": ["-d stats"]
policeman0077
I'll try thank you for your advice
