I have a question about high negative voltage on osilloscope. I am trying to start and stop control DC motor with TIP122 transistor by signaling D3 pin on ESP-C3-13 kit. There's no problem when I set HIGH D3 pin and scope displays ~12V without any noise. Things getting weird when I set LOW D3 pin. When I set D3 to LOW, scope show -67 V with unstable graph.
I checked FFT graph and found out many noise inside the signal, but it is an easy circuit and shouldn't have kind of noise. If I face with noise I should see same problem at FFT graph on +12V too. Am I correct?
So, can anybody make a comment why I am facing -67 V with unstable graph when I set D3 pin to LOW?
As an additional information, multimeter measure 0 voltage level whereas I see that high negative voltage level on scope when D3 is LOW.
Please note that scope probes attached to motor pins. Even if I drop motor from circuit, I face with same problem.
Please find scheme and scope outputs.
-67V with large scale:
-67V with FFT (FFT graph is red):
12v stable:
Thank you for your helps,
Orkun Gedik
High negative voltage on scope
Re: High negative voltage on scope
Schema is here: Hi,
12v stable:
Orkun Gedik
Craige Hales
check the Q1 part number. Double check the pinout.
The scope ground must be connected to the circuit ground (not a motor pin.)
https://electronics.stackexchange.com/q ... transistor hints the 10K resistor might be too big.
Scope probe to the base on Q1:
It's been a long time, but I think it has to be high (5V) to turn it on and low (gnd) to turn it off.
Scope probe to the collector:
if Q1 is on, the collector should be near ground, not 12V.
if Q1 is off and the motor provides a path to 12V, the collector should be near 12V.
if there is no motor installed, I think you might expect to see noise when Q1 is off.
Craige
Hi Craige,check the Q1 part number. Double check the pinout.
Thank you for your precious information. Very informative for my learning path.
Best regards,
Orkun Gedik
Users browsing this forum: Bing [Bot], PetalBot and 2 guests
