I would like to use custom interrupts for handling UART rx. The reason I cannot use event queues is that I will sometimes need to reply within 300us of receiving a byte (and event queues have more latency than that due to FreeRTOS context switches).
Note: I do not need high throughput, only low latency.
In ESP IDF v4.4.5, there was an API to register a custom interrupt handler (https://docs.espressif.com/projects/esp ... interrupts - see
uart_is_registerHowever, as of ESP IDF v5 this API no longer exists, with no note in the migration guide and seemingly no replacement. Busy looping
uart_read_bytesHow can I implement low-latency UART communication using the ESP IDF v5+?
Thank you so much in advance!
