One simple HTTS login Post call with body like:
"username": "test",
"password": "test"
Is it always that slow? It takes a whole second just for TLS handshake (See log). Do you have similiar experiences?
Is there any ways to improve that speed?
code:
.url = API_URL "users/login",
.method = HTTP_METHOD_POST,
.user_data = local_response_buffer,
.crt_bundle_attach = esp_crt_bundle_attach,
.event_handler = _http_event_handler};
cJSON *root = cJSON_CreateObject();
cJSON *name = cJSON_CreateString(creds->username);
cJSON *password = cJSON_CreateString(creds->password);
cJSON_AddItemToObject(root, "username", name);
cJSON_AddItemToObject(root, "password", password);
char *json_string = cJSON_Print(root);
ESP_LOGI(TAG, "Token: %s", json_string); // FROM HERE
esp_http_client_handle_t client = esp_http_client_init(&config);
esp_http_client_set_header(client, "Content-Type", "application/json");
esp_http_client_set_post_field(client, json_string, strlen(json_string));
esp_err_t err = esp_http_client_perform(client);
if (err == ESP_OK && (esp_http_client_get_status_code(client) == 200))
ESP_LOGI(TAG, "TEST"); // TO HERE IT TAKES 2.5 secsCode: Select all
Verbose Logs
I (227622) KICKER_CLUB: Token: {
"username": "****",
"password": "****"
D (227632) HTTP_CLIENT: set post file length = 56
D (227632) HTTP_CLIENT: Begin connect to: https://********.de:443
D (227642) esp-tls: ******.de: strlen 26
W (227662) wifi:<ba-add>idx:0 (ifx:0, b8:27:eb:f1:6d:9c), tid:0, ssn:2, winSize:64
D (227692) esp-tls: [sock=58] Resolved IPv4 address: *******
D (227692) esp-tls: [sock=58] Connecting to server. HOST: ****
D (227722) esp-tls-mbedtls: Use certificate bundle
D (227722) esp-tls: handshake in progress...
D (227832) esp-x509-crt-bundle: 127 certificates in bundle
I (227862) esp-x509-crt-bundle: Certificate validated
D (228762) HTTP_HANDLER: HTTP_EVENT_ON_CONNECTED
D (228762) HTTP_CLIENT: Write header[4]: POST /api/users/login HTTP/1.1
User-Agent: ESP32 HTTP Client/1.0
Host: ****
Content-Type: application/json
Content-Length: 56
D (228782) HTTP_HANDLER: HTTP_EVENT_HEADER_SENT
D (229362) HTTP_CLIENT: on_message_begin
D (229362) HTTP_CLIENT: HEADER=Date:Sat, 16 Apr 2022 16:07:28 GMT
D (229362) HTTP_HANDLER: HTTP_EVENT_ON_HEADER, key=Date, value=Sat, 16 Apr 2022 16:07:28 GMT
D (229362) HTTP_CLIENT: HEADER=Content-Type:application/json
D (229372) HTTP_HANDLER: HTTP_EVENT_ON_HEADER, key=Content-Type, value=application/json
D (229382) HTTP_CLIENT: HEADER=Transfer-Encoding:chunked
D (229382) HTTP_HANDLER: HTTP_EVENT_ON_HEADER, key=Transfer-Encoding, value=chunked
D (229392) HTTP_CLIENT: HEADER=Connection:keep-alive
D (229402) HTTP_HANDLER: HTTP_EVENT_ON_HEADER, key=Connection, value=keep-alive
D (229402) HTTP_CLIENT: HEADER=Server:nginx/1.15.1
D (229412) HTTP_HANDLER: HTTP_EVENT_ON_HEADER, key=Server, value=nginx/1.15.1
D (229422) HTTP_CLIENT: HEADER=Vary:Origin
D (229422) HTTP_HANDLER: HTTP_EVENT_ON_HEADER, key=Vary, value=Origin
D (229432) HTTP_CLIENT: HEADER=Vary:Access-Control-Request-Method
D (229432) HTTP_HANDLER: HTTP_EVENT_ON_HEADER, key=Vary, value=Access-Control-Request-Method
D (229442) HTTP_CLIENT: HEADER=Vary:Access-Control-Request-Headers
D (229452) HTTP_HANDLER: HTTP_EVENT_ON_HEADER, key=Vary, value=Access-Control-Request-Headers
D (229462) HTTP_CLIENT: HEADER=X-Content-Type-Options:nosniff
D (229462) HTTP_HANDLER: HTTP_EVENT_ON_HEADER, key=X-Content-Type-Options, value=nosniff
D (229472) HTTP_CLIENT: HEADER=X-XSS-Protection:1; mode=block
D (229482) HTTP_HANDLER: HTTP_EVENT_ON_HEADER, key=X-XSS-Protection, value=1; mode=block
D (229482) HTTP_CLIENT: HEADER=Cache-Control:no-cache, no-store, max-age=0, must-revalidate
D (229492) HTTP_HANDLER: HTTP_EVENT_ON_HEADER, key=Cache-Control, value=no-cache, no-store, max-age=0, must-revalidate
D (229502) HTTP_CLIENT: HEADER=Pragma:no-cache
D (229512) HTTP_HANDLER: HTTP_EVENT_ON_HEADER, key=Pragma, value=no-cache
D (229512) HTTP_CLIENT: HEADER=Expires:0
D (229522) HTTP_HANDLER: HTTP_EVENT_ON_HEADER, key=Expires, value=0
D (229522) HTTP_CLIENT: HEADER=X-Frame-Options:DENY
D (229532) HTTP_HANDLER: HTTP_EVENT_ON_HEADER, key=X-Frame-Options, value=DENY
D (229542) HTTP_CLIENT: http_on_headers_complete, status=200, offset=431, nread=431
D (229542) HTTP_CLIENT: http_on_chunk_header, chunk_length
D (229552) HTTP_CLIENT: http_on_body 76
D (229552) HTTP_HANDLER: HTTP_EVENT_ON_DATA, len=76
D (229562) HTTP_CLIENT: content_length = -1
D (229562) HTTP_CLIENT: data_process=76, content_length=-1
D (229572) TRANSPORT_BASE: remain data in cache, need to read again
D (229572) HTTP_CLIENT: http_on_body 327
D (229582) HTTP_HANDLER: HTTP_EVENT_ON_DATA, len=327
D (229582) HTTP_CLIENT: http_on_chunk_complete
D (229592) HTTP_CLIENT: data_process=403, content_length=-1
D (229602) HTTP_CLIENT: http_on_chunk_header, chunk_length
D (229602) HTTP_CLIENT: http_on_chunk_complete
D (229602) HTTP_CLIENT: http_on_message_complete, parser=3ffb21ec
D (229612) HTTP_HANDLER: HTTP_EVENT_ON_FINISH
D (229612) HTTP_HANDLER: ***
I (229652) KICKER_CLUB: TEST
