which ESP32 can read from BT HID keyboard (e.g., scanf(), gets(), std::cin ) ?
is there a ESP32 version which can connect to a BT HID keyboard and then read user input via stdin (e.g., scanf(), gets(), std::cin ) ?
lbernstone
Re: which ESP32 can read from BT HID keyboard (e.g., scanf(), gets(), std::cin ) ?
https://products.espressif.com
ESP32 has BT + BLE
ESP32-S2 has no bluetooth
All other variants are BLE only
ESP32 has BT + BLE
what means BLE?
now which one can detect and connect to a BT HID keyboard and then read input?
which BT (or whatever) keyboards are supported?
Where can keyboard ino examples be found for Arduino IDE?
no ideas?
or HID keyboards not possible?
It's certainly possible, e.g. https://github.com/Spritetm/esp32c3-doo ... nimble-hid is an ESP-IDF project that talks to a BTLE keyboard (or other HID device). It uses an event interface, but you could code it up to a newlib file descriptor to use sscanf etc on it. I don't think anyone did that, however, and I'm not sure if there's an Arduino equivalent either.
thank you, but I do not understand.
1st, there are no demo pictures and no explanations in your link,
2nd, I need Arduino IDE/API for it, no IDF, and
3rd, I cannot see how this linked lib would work with exactly which BT HID keyboard types (all types? e.g. this one?
https://www.amazon.de/Rii-Bluetooth-Mul ... 3%95%C3%91,
beginning with stand-allone BT-pairing after board-boot/startup.
OTOH, for general programming usage I would need it for standard C or C++ libs (stdio.h/cstdio, std::cin) to work out of the box.
Okay, let me be clearer: it certainly is *possible* to do what you need, and the parts that a competent programmer can use to implement this are there, but if you need an out-of-the-box solution that does exactly what you want, you're out of luck as to my knowledge that does not exist.
Thank you for your reply.
I actually had expected the ESP32-Arduino API to have more such features meanwhile, tbh...
Users browsing this forum: Google [Bot] and 2 guests
