ESP32 Direct coax wi-fi connection
I want to connect two ESP32 DevKits with an external antenna connector using coax cable. Is it possible to directly connect them without an attenuator? I have them working with two 30 Db attenuators and a T to connect a tinySA and I am getting around -25 dBm at the T. I am using ESP_NOW and Arduino for my program and have not found a way to change the TX power output. I have tried WiFi.setTxPower(WIFI_POWER_2dBm); in the setup but it doesn't change the power output when using ESP_NOW. Any help would be greatly appreciated.
Re: ESP32 Direct coax wi-fi connection
Remove the connector from PCB and solder mid to mid shield to any side of it. I'm using many in this way
Thank you for your response. Do you connect them directly or use an attenuator?
Craige Hales
@thezcx - Can you post a picture showing what you are doing? Sounds interesting.
I've used this on a wroom32 (pcb antenna) with a streaming wifi web socket:
The value 8 works over very short distances (10 feet maybe) and gives me a lower ADC noise than 52 to 80. I'm pretty sure the wifi tx is getting into the sensor.
static int8_t const sPowers[] = {8, 20, 28, 34, 44, 52, 56, 60, 66, 72, 80};
ESP_ERROR_CHECK_WITHOUT_ABORT(esp_wifi_set_max_tx_power(sPowers[p]));
Craige
Users browsing this forum: ChatGPT-User, PetalBot and 2 guests
