ESP32-DevKitM-1 v1.0
dpavlovic
Postby dpavlovic » Fri Nov 25, 2022 2:21 pm
I have ESP32-DevKitM-1 v1.0
I'm using Arduino
I installed as per your instructions
Which board should I choose?
Whichever board I choose I get this attached
Minatel
Re: ESP32-DevKitM-1 v1.0
Postby Minatel » Fri Nov 25, 2022 3:51 pm
ESP32 Dev Module
ks1956
Postby ks1956 » Thu Nov 30, 2023 9:30 pm
ESP32 Dev Module
I have tried to select ESP32 Dev Module . But no luck. My board (ESP32 DevKitM1 V 1.0) not getting recognized.
Only the Power ON light remains on.Please help.
ks1956
Postby ks1956 » Fri Dec 01, 2023 5:09 am
My problem is the board does not get recognized. I installed ESP32 properly on the Arduino board manager.
I selected ESP Dev from the dropdown list displayed on Arduino.
Why is my board (ESP32 DEVKit M-1 V 1.0 ) not displayed on Arduino.?
Postby Sprite » Fri Dec 01, 2023 5:57 am
Maybe obvious, but are you sure the USB cable you use isn't charging-only?
lbernstone
Postby lbernstone » Fri Dec 01, 2023 7:03 am
ESP32-devkitM v1.0 is a unicore processor. It is supported by ESP-IDF and the tasmota framework, but not arduino-esp32. Newer versions are dual core.
Users browsing this forum: Barkrowler, meta-externalagent and 1 guest
