I'm writing a C++ framework on top of FreeRTOS/ESP-IDF in order to allow application development on ESP-IDF "fully C++" and also remove a lot of the hassle/pitfalls associated with multi threading. So far I've got classes for Tasks, Queues, Mutexes, Socket, Timers, Performance timers and a (memory static) Finite State Machine.
This is all working out very well and I've also begun to implement MQTT support as an example of how these things are used. Feel free to check out the project at GitHub and join if you like
Naturally I've hit a few quite a few bumps on the way but so far I've managed to solve them all. There is however one very intermittent issue causing an application crash that I'm not able to figure out. I've captured two stacktraces and although not identical they both share the same initial entrypoint (search for forward_to_taskEv in the traces) so I suspect they have the same root cause.
Can anyone of you read any useful information from these traces? All I can see is that the first one fails inside std::shared_ptr during destruction (xtensa-esp32-elf/include/c++/5.2.0/ext/new_allocator.h:124). It makes total sense that this code is executing since class ConnectionStatusEvent contains a shared_ptr), but I see no reason for it to crash at this point - it should just do what is needed to destroy the shared_ptr and continue, as it has done many many times already before it eventually fails like this.
I'm running this on a Sparkfun ESP32thing, using ESP-IDF master, commit dce7fcb90d5374c7c662323f7ab50fc28e98e2f2 and compiler xtensa-esp32-elf-linux64-1.22.0-61-gab8375a-5.2.0.tar.gz.
Update: When forcing FreeRTOS to only run on a single core I have not yet seen this issue.
Any insights will be very appreciated.
V (127042) Socket: [192.168.10.247, 1883, 0x3ffcc71c]: Stopping
V (127042) SocketDispatcher: Initiating shutdown of socket 0x3ffcc71c
V (127042) Socket: [192.168.10.247, 1883, 0x3ffcc71c]: Disconnected
V (127052) SocketDispatcher: Completing shutdown of socket 0x3ffcc71c
V (127052) Socket: [192.168.10.247, 1883, 0x3ffcc768]: Created socket
V (127062) Socket: [192.168.10.247, 1883, 0x3ffcc71c]: Destructing
V (127072) Socket: [192.168.10.247, 1883, 0x3ffcc768]: Connecting
Guru Meditation Error of type LoadProhibited occurred on core 1. Exception was unhandled.
Register dump:
PC : 0x4010222b PS : 0x00060730 A0 : 0x8010239c A1 : 0x3ffcc0c0
0x4010222b: _ZNSt16_Sp_counted_baseILN9__gnu_cxx12_Lock_policyE0EE10_M_releaseEv at /home/permal/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/bits/shared_ptr_base.h:309
(inlined by) _ZNSt14__shared_countILN9__gnu_cxx12_Lock_policyE0EED4Ev at /home/permal/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/bits/shared_ptr_base.h:659
(inlined by) _ZNSt12__shared_ptrIN6smooth4core7network7ISocketELN9__gnu_cxx12_Lock_policyE0EED4Ev at /home/permal/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/bits/shared_ptr_base.h:925
(inlined by) _ZNSt10shared_ptrIN6smooth4core7network7ISocketEED4Ev at /home/permal/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/bits/shared_ptr.h:93
(inlined by) _ZN6smooth4core7network21ConnectionStatusEventD4Ev at /home/permal/code/SmoothTest/components/Smooth/include/smooth/core/network/ConnectionStatusEvent.h:16
(inlined by) _ZN9__gnu_cxx13new_allocatorIN6smooth4core7network21ConnectionStatusEventEE7destroyIS4_EEvPT_ at /home/permal/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/ext/new_allocator.h:124
(inlined by) _ZNSt16allocator_traitsISaIN6smooth4core7network21ConnectionStatusEventEEE10_S_destroyIS3_EENSt9enable_ifIXsrSt6__and_IJNS5_16__destroy_helperIT_E4typeEEE5valueEvE4typeERS4_PSA_ at /home/permal/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/bits/alloc_traits.h:285
(inlined by) _ZNSt16allocator_traitsISaIN6smooth4core7network21ConnectionStatusEventEEE7destroyIS3_EEvRS4_PT_ at /home/permal/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/bits/alloc_traits.h:414
(inlined by) _ZNSt6vectorIN6smooth4core7network21ConnectionStatusEventESaIS3_EE8_M_eraseEN9__gnu_cxx17__normal_iteratorIPS3_S5_EE at /home/permal/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/bits/vector.tcc:147
A2 : 0x3ffcc750 A3 : 0x0000000b A4 : 0x3ffc0a04 A5 : 0x00000000
A6 : 0x3ffc0a20 A7 : 0x3ffc0738 A8 : 0x80084452 A9 : 0x3ffcc090
A10 : 0x3ffc0a04 A11 : 0x3ffcc0f0 A12 : 0x00000000 A13 : 0x0000ff00
A14 : 0x00ff0000 A15 : 0xff000000 SAR : 0x00000018 EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000013 LBEG : 0x4000c349 LEND : 0x4000c36b LCOUNT : 0xffffffff
Backtrace: 0x4010222b:0x3ffcc0c0 0x40102399:0x3ffcc0f0 0x4012f571:0x3ffcc130 0x4012f5b9:0x3ffcc170
0x40102399: _ZThn4_N6smooth4core3ipc14TaskEventQueueINS0_7network21ConnectionStatusEventEE15forward_to_taskEv at ??:?
0x4012f571: _ZN6smooth4core4Task4execEv at /home/permal/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/bits/char_traits.h:243
0x4012f5b9: _ZZN6smooth4core4Task5startEvENUlPvE_4_FUNES2_ at /home/permal/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/bits/char_traits.h:243
(inlined by) _FUN at /home/permal/code/SmoothTest/components/Smooth/core/Task.cpp:62
Entering gdb stub now.
$T0b#e6GNU gdb (crosstool-NG crosstool-ng-1.22.0-61-gab8375a) 7.10
Copyright (C) 2015 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type "show copying"
and "show warranty" for details.
This GDB was configured as "--host=x86_64-build_pc-linux-gnu --target=xtensa-esp32-elf".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from /home/permal/code/SmoothTest/build/Smooth-test.elf...done.
Remote debugging using /dev/ttyUSB0
0x4010222b in std::_Sp_counted_base<(__gnu_cxx::_Lock_policy)0>::_M_release (this=0x3ffcc750)
309 _M_dispose();
(gdb)
(gdb) bt
#0 0x4010222b in std::_Sp_counted_base<(__gnu_cxx::_Lock_policy)0>::_M_release (this=0x3ffcc750)
#1 std::__shared_count<(__gnu_cxx::_Lock_policy)0>::~__shared_count (this=<optimized out>, __in_chrg=<optimized out>)
#2 std::__shared_ptr<smooth::core::network::ISocket, (__gnu_cxx::_Lock_policy)0>::~__shared_ptr (this=<optimized out>, __in_chrg=<optimized out>)
#3 std::shared_ptr<smooth::core::network::ISocket>::~shared_ptr (this=<optimized out>, __in_chrg=<optimized out>)
#4 smooth::core::network::ConnectionStatusEvent::~ConnectionStatusEvent (this=<optimized out>, __in_chrg=<optimized out>)
#5 __gnu_cxx::new_allocator<smooth::core::network::ConnectionStatusEvent>::destroy<smooth::core::network::ConnectionStatusEvent> (__p=<optimized out>, this=0x3ffbbd20)
#6 std::allocator_traits<std::allocator<smooth::core::network::ConnectionStatusEvent> >::_S_destroy<smooth::core::network::ConnectionStatusEvent> (__p=<optimized out>, __a=...)
#7 std::allocator_traits<std::allocator<smooth::core::network::ConnectionStatusEvent> >::destroy<smooth::core::network::ConnectionStatusEvent> (__p=<optimized out>, __a=...)
#8 std::vector<smooth::core::network::ConnectionStatusEvent, std::allocator<smooth::core::network::ConnectionStatusEvent> >::_M_erase (this=0x3ffbbd20, __position=...)
#9 0x4010239c in non-virtual thunk to smooth::core::ipc::TaskEventQueue<smooth::core::network::ConnectionStatusEvent>::forward_to_task() ()
at /home/permal/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/bits/shared_ptr_base.h:311
#10 0x4012f574 in smooth::core::Task::exec (this=0x3ffbb9b0) at /home/permal/code/SmoothTest/components/Smooth/core/Task.cpp:93
#11 0x4012f5bc in smooth::core::Task::<lambda(void*)>::operator() (
/home/ivan/e/crosstool-NG/.build/src/gdb-7.10/gdb/inline-frame.c:167: internal-error: inline_frame_this_id: Assertion `frame_id_p (*this_id)' failed.
A problem internal to GDB has been detected,
further debugging may prove unreliable.
Quit this debugging session? (y or n)
Guru Meditation Error of type InstrFetchProhibited occurred on core 0. Exception was unhandled.
Register dump:
PC : 0x00000000 PS : 0x00060830 A0 : 0x801047df A1 : 0x3ffc3540
A2 : 0x3ffbbd48 A3 : 0x3ffc35a4 A4 : 0x00000000 A5 : 0xc0000000
A6 : 0x00000034 A7 : 0x00000001 A8 : 0x80104734 A9 : 0x3ffbbfa0
A10 : 0x3ffaf40c A11 : 0x00060823 A12 : 0x00060820 A13 : 0x3ffc35a0
A14 : 0x00000000 A15 : 0x00000000 SAR : 0x00000006 EXCCAUSE: 0x00000014
EXCVADDR: 0x00000000 LBEG : 0x4000c2e0 LEND : 0x4000c2f6 LCOUNT : 0xffffffff
Backtrace: 0x00000000:0x3ffc3540 0x401047dc:0x3ffc3580 0x40102d23:0x3ffc35a0 0x401346a5:0x3ffc35d0 0x401346ed:0x3ffc3610
0x401047dc: _ZThn92_N10LedControl7messageERKN6smooth4core5timer17TimerExpiredEventE at ??:?
0x40102d23: _ZThn4_N6smooth4core3ipc14TaskEventQueueINS0_5timer17TimerExpiredEventEE15forward_to_taskEv at ??:?
0x401346a5: _ZN6smooth4core4Task4execEv at /home/permal/code/SmoothTest/components/Smooth/core/Task.cpp:93
0x401346ed: _ZZN6smooth4core4Task5startEvENUlPvE_4_FUNES2_ at /home/permal/code/SmoothTest/components/Smooth/core/Task.cpp:62
0x00000000 in ?? ()
(gdb) bt
#0 0x00000000 in ?? ()
#1 0x001047df in ?? ()
#2 0x00102d26 in ?? ()
#3 0x001346a8 in ?? ()
#4 0x001346f0 in ?? ()
(gdb)
