/* I2C port and GPIOs */
#define I2C_NUM (0)
#define I2C_SDA_IO (GPIO_NUM_17)
#define I2C_SCL_IO (GPIO_NUM_18)
/* I2S port and GPIOs */
#define I2S_NUM (0)
#define I2S_MCK_IO (GPIO_NUM_16)
#define I2S_BCK_IO (GPIO_NUM_9)
#define I2S_WS_IO (GPIO_NUM_45)
#define I2S_DO_IO (GPIO_NUM_10)
#define I2S_DI_IO (GPIO_NUM_8)
/* Example configurations */
#define EXAMPLE_RECV_BUF_SIZE (2048)
#define EXAMPLE_SAMPLE_RATE (16000)
#define EXAMPLE_MCLK_MULTIPLE I2S_MCLK_MULTIPLE_256
#define EXAMPLE_VOICE_VOLUME CONFIG_EXAMPLE_VOICE_VOLUME
#if CONFIG_EXAMPLE_MODE_ECHO
#define EXAMPLE_MIC_GAIN CONFIG_EXAMPLE_MIC_GAIN
#endif
日志:
I (339) heap_init: Initializing. RAM available for dynamic allocation:
I (346) heap_init: At 3FC953D8 len 00054338 (336 KiB): D/IRAM
I (353) heap_init: At 3FCE9710 len 00005724 (21 KiB): STACK/DIRAM
I (360) heap_init: At 3FCF0000 len 00008000 (32 KiB): DRAM
I (366) heap_init: At 600FE000 len 00002000 (8 KiB): RTCRAM
I (373) spi_flash: detected chip: gd
I (376) spi_flash: flash io: dio
W (380) spi_flash: Detected size(16384k) larger than the size in the binary image header(2048k). Using the size in the binary image header.
I (394) sleep: Configure to isolate all GPIO pins in sleep state
I (400) sleep: Enable automatic switching of GPIO sleep configuration
I (408) cpu_start: Starting scheduler on PRO CPU.
I (429) I2S: DMA Malloc info, datalen=blocksize=256, dma_buf_count=8
I (439) I2S: I2S0, MCLK output by GPIO16
I (459) ES8311: ES8311 in Slave mode and I2S format
I (10439) i2s_es8311: [music] i2s music played, 640000 bytes are written.
I (21409) i2s_es8311: [music] i2s music played, 640000 bytes are written.
