ESP32-S2 memory leak
atlaste
Postby atlaste » Mon Feb 05, 2024 3:56 pm
We're using LWIP to do async TCP/IP connections. During the development, we've found two memory leaks that we cannot explain; one of them roughly 16 bytes, the other one roughly 1.6 KB
Here are the relevant stack traces:
Lost ptr=3FFE43B8 size=1696
heap_caps_malloc_base
C:/Espressif/frameworks/esp-idf-v5.1/components/heap/heap_caps.c:178 (discriminator 1)
heap_caps_malloc
C:/Espressif/frameworks/esp-idf-v5.1/components/heap/heap_caps.c:197
heap_caps_malloc_default
C:/Espressif/frameworks/esp-idf-v5.1/components/heap/heap_caps.c:223
malloc
C:/Espressif/frameworks/esp-idf-v5.1/components/newlib/heap.c:24
wifi_malloc
C:/Espressif/frameworks/esp-idf-v5.1/components/esp_wifi/esp32s2/esp_adapter.c:65
esf_buf_alloc_dynamic
esf_buf_alloc
wDev_IndicateFrame
wDev_ProcessRxSucData
wdevProcessRxSucDataAll
ppTask
vPortTaskWrapper
C:/Espressif/frameworks/esp-idf-v5.1/components/freertos/FreeRTOS-Kernel/portable/xtensa/port.c:162
and:
Lost ptr=3FFE0238 size=28
heap_caps_malloc
malloc
mem_malloc
C:/Espressif/frameworks/esp-idf-v5.1/components/lwip/lwip/src/core/mem.c:209
esp_pbuf_allocate
C:/Espressif/frameworks/esp-idf-v5.1/components/esp_netif/lwip/netif/esp_pbuf_ref.c:52
wlanif_input
C:/Espressif/frameworks/esp-idf-v5.1/components/esp_netif/lwip/netif/wlanif.c:151
esp_netif_receive
C:/Espressif/frameworks/esp-idf-v5.1/components/esp_netif/lwip/esp_netif_lwip.c:1221
wifi_sta_receive
C:/Espressif/frameworks/esp-idf-v5.1/components/esp_wifi/src/wifi_netif.c:39
sta_input
sta_rx_cb
ppRxPkt
ppTask
vPortTaskWrapper
We're attempting to figure out why the code is leaking, but unfortunately lack the relevant code to properly troubleshoot this. We already confirmed that we call tcp_close (and tcp_abort if that doesn't succeed) on the LWIP connections. Please advice,
Stefan.
atlaste
Re: ESP32-S2 memory leak
Postby atlaste » Tue Feb 06, 2024 12:13 pm
For the record, this leak consistently occurs when we accept a connection with LWIP, do some send/recv operations on the socket and then close it (close / abort). We then wait for a few seconds for TCP FIN to occur before checking the heap status, and find that 1.6 KB is gone.
We can reproduce the problem as often as we like, by just doing the same thing over and over again.
atlaste
Postby atlaste » Tue Feb 13, 2024 1:58 pm
Well, for anyone else bumping into this. The issue was that lwip_recv callbacks need to do a pbuf_free. The stack traces just make this confusing.
Anyways, problem solved.
Users browsing this forum: Qwantbot, Semrush [Bot] and 8 guests
