Unknown CMake command error VSCode
NicoCaldo
Postby NicoCaldo » Mon Feb 05, 2024 4:30 pm
I've installed the ESP-IDF via VS Code following the official documentation here https://github.com/espressif/vscode-esp ... install.md
Everything works fine expect that, for some reason, I'm having an error on the CMakeLists.txt
CMake Error at CMakeLists.txt:6 (include):include could not find requested file:
  /tools/cmake/project.cmake
CMake Error at CMakeLists.txt:10 (target_add_binary_data):Unknown CMake command "target_add_binary_data".
What's wrong?
bignacio
Re: Unknown CMake command error VSCode
Postby bignacio » Wed Feb 07, 2024 4:41 am
Could you provide some troubleshooting information as described in :
https://github.com/espressif/vscode-esp ... leshooting
From the output I suspect there is some space in one of the configuration settings path.I would make sure to use a directory with no spaces.
