Embedding assembly code fragment in main source file in ESP-IDF
Vilius
Postby Vilius » Tue Feb 27, 2024 6:52 am
I am developing a code (on ESP32 WROOVER-E) that could potentially hugely benefit from rewriting some short fragment of C code in assembly language. Having said that, I still want to preserve the rest of the source file unchanged. Can you please provide me with some short snipet or pseudocode what is the syntax for such scenario? I will write the assembly on my own, I just need some guidance, are there any specific includes needed for it, is there specific syntax highlighting the assembly code beginning and end? Thank you in advance.
The code:
#includes
void app main(){
while(1){
//This part will be rewritten in assembly
REG_WRITE(GPIO_OUT_W1TS_REG, (1 << GPIO_CLOCK));
data_array[k] = REG_READ(GPIO_IN_REG);
data_array[k + 1] = REG_READ(GPIO_IN1_REG);
k = (k + 2) % NUM_CYCLES;
REG_WRITE(GPIO_OUT_W1TC_REG, (1 << GPIO_CLOCK));
//assembly section ends here
MicroController
Re: Embedding assembly code fragment in main source file in ESP-IDF
Postby MicroController » Tue Feb 27, 2024 8:19 am
See https://gcc.gnu.org/onlinedocs/gcc/exte ... -code.html
However, your code snippet is really simple and chances are that gcc already generates pretty optimal code. Before resorting to assembler, you generally should check gcc's output to verify if there actually is any potential for further optimization.
Vilius
Postby Vilius » Tue Feb 27, 2024 8:40 am
Reading the datasheet implies that it is still worth trying. So can you provide me the assembly details? I tried to do it by myself, but ESP-IDF was giving me syntax errors. Does anyone have a very simple and working assembly block syntax template?
MicroController
Postby MicroController » Tue Feb 27, 2024 9:13 am
Your code could start with something like this:
uint32_t* dataPtr = data_array;
uint32_t tmp;
asm volatile (
  "S32I %[clk], %[w1ts], 0" "\n"
  "memw" "\n"
  "L32I %[tmp], %[in0], 0" "\n"
  "S32I %[tmp], %[dataPtr], 0" "\n"
  "L32I %[tmp], %[in1], 0" "\n"
  "S32I %[tmp], %[dataPtr], 4" "\n"
  "memw" "\n"
  "S32I %[clk], %[w1tc], 0" "\n"
  "memw" "\n"
  "ADDI %[dataPtr], %[dataPtr], 8" "\n"
  : [dataPtr] "+r" (dataPtr),
    [tmp] "=&r" (tmp),
    "=m" (data_array)
  : [w1ts] "r" (w1ts_reg_addr),
    [w1tc] "r" (w1tc_reg_addr),
    [clk] "r" (1<<GPIO_CLOCK),
    [in0] "r" (gpio_in_addr),
    [in1] "r" (gpio_in1_addr)
Last edited by MicroController on Tue Feb 27, 2024 9:58 pm, edited 4 times in total.
MicroController
Postby MicroController » Tue Feb 27, 2024 9:58 am
Btw, note that GPIO on the ESP is slow; the CPU is usually not the bottleneck.
DrMickeyLauer
Postby DrMickeyLauer » Tue Feb 27, 2024 11:24 am
How slow is "slow"? I have a design where one GPIO is toggling VSYS (12V) to an external pin and another GPIO can be used to read that pin. I'm working on my board testing code and in my first naive attempts I was under the assumption that the moment gpio_set_level(outputPin) returns, the pin has changed its level and I can gpio_get_level(inputPin). Alas that doesn't work and I need to add a delay between these two instructions. I'd like to find out how long I need to wait.
Postby Sprite » Wed Feb 28, 2024 1:41 am
Independent of latency of the GPIO, writes and reads are always done 'in order', that is, a write always completes before a read instruction that follows it is executed. I think your issue may be more one of an analog nature, e.g. there might be some capacitance on the pin that initially keeps it on the same level. (Note that if you program in assembly, you may need to have a memw between the read and write, so the CPU also keeps the execution in order. In C, this is already handled automatically.)
Users browsing this forum: Bytespider, Qwantbot, Semrush [Bot], YisouSpider and 1 guest
