ESP32 Deep Sleep External Wake Up Query
Phillip
Postby Phillip » Mon Feb 26, 2024 4:19 pm
In the Deep Sleep function call:
esp_sleep_enable_ext0_wakeup(GPIO_NUM_X, level)
Is it possible to determine the logic state of 'GPIO_NUM_X'?
I have tried the followig -
if (GPIO_NUM_X == HIGH)
       do something here ...
but this does not execute.
Any help with this would be much appreciated.
Thank you.
Phillip
Re: ESP32 Deep Sleep External Wake Up Query
Postby Phillip » Tue Feb 27, 2024 3:51 am
To those who may have some interest in this issue, I can up with this Plan B solution.
I solved my problem by using another GPIO in parallel with the 'GPIO_NUM_X' pin. IOW's, I connected my 'trigger' lead to both the 'GPIO_NUM_X' pin and another GPIO pin. They both go HIGH/LOW simultaneously.
I needed to know when the GPIO_NUM_X went HIGH and performing a digitalRead() on the second interconnected pin gave me the info I needed.
Problem solved.
Thanks!
lbernstone
Postby lbernstone » Tue Feb 27, 2024 6:07 pm
The ext1 peripheral can identify which pin caused the wakeup, but does not work exactly like ext0.
Phillip
Postby Phillip » Tue Feb 27, 2024 6:31 pm
@Ibernstone
Thanks for your post.
I'm a bit embarrassed because I reviewed the original sketch that I was having the 'GPIO_NUM_33' problem with and it seems that my
reading = digitalRead(GPIO_NUM_33);
code line was mistyped or something else. I retyped that code line and all was good.
The lines seemed identical but apparently they were not. That line now works as expected and I am good to go. Live and learn.
Thanks again.
Users browsing this forum: Google [Bot], PerplexityBot and 1 guest
