A fatal error occurred: Packet content transfer stopped (received 8 bytes) on EPS32-S3 PCB.
faizannazir289
Re: A fatal error occurred: Packet content transfer stopped (received 8 bytes) on EPS32-S3 PCB.
Postby faizannazir289 » Sat Mar 09, 2024 8:19 pm
 esptool flash_id
esptool.py v4.7.0
Found 3 serial ports
Serial port COM9
Connecting...
Detecting chip type... ESP32-C3
Chip is ESP32-C3 (QFN32) (revision v0.4)
Features: WiFi, BLE
Crystal is 40MHz
MAC: dc:da:0c:8e:a0:bc
Uploading stub...
Running stub...
Stub running...
Manufacturer: 3f
Device: ffff
Detected flash size: Unknown
Hard resetting via RTS pin...
Postby Sprite » Sat Mar 09, 2024 11:59 pm
Suggest you start your own topic, with more information than just the dump from esptool: what hw do you have, what actual flash chip is in there?
