Greetings,
I am using ESP-IDF with an Adafruit Qt Py ESP32-S3, which has the following pinouts:
https://cdn-learn.adafruit.com/assets/a ... pdated.png
I would like to redirect the standard ESP_LOGI logging and other console output to use TX=GPIO5, RX=GPIO16, as per the labeling of the Qt Py.
I tried a lot of combinations of "idf.py menuconfig" and could not get it to work. I have verified, by using Arduino, that the hardware works: I can indeed log to these pins.
I would greatly appreciate if someone would list the exact "sdkconfig" settings and/or "idf.py menuconfig" actions to do this!
Thank you!
Ihab
ESP32-S3 log to non-default UART pins
Re: ESP32-S3 log to non-default UART pins
It's under Component config → ESP System Settings. For 'Channel for console output', you can select 'Custom UART', and that lets you select the Tx and Rx pins.
Users browsing this forum: Qwantbot and 5 guests
