After doing a git pull & git submodules update today something went wrong.
As usual I did a make menuconfig immediately after the sdk update and found that the ESP menu option was missing
When doing a make all immediately afterwards it complained about a large number of macros definitions being missing. Some of the missing macros included..
CONFIG_ESP32_DEFAULT_CPU_FREQ_MHZ
CONFIG_ESP32_XTAL_FREQ 0
CONFIG_CONSOLE_UART_NUM
CONFIG_CONSOLE_UART_BAUDRATE
CONFIG_FREERTOS_MAX_TASK_NAME_LEN
CONFIG_TCP_OVERSIZE_xxx
CONFIG_FREERTOS_HZ
and numerous others.
Any suggestions for what I did wrong??
Help appreciated
AM
Missing ESP32 option in make menuconfig
Re: Missing ESP32 option in make menuconfig
Hi ammaree,
If you run "make defconfig", do you get any warnings or errors in the output? (These are also printed when you run "make menuconfig", but the ncurses menu pops up over the top of them.)
Angus
Angus
Nope, no errors.
Output from make after having done menuconfig$ make defconfig
DEFCONFIG
# configuration written to /c/Dropbox/devs/ws/esp32/esp-phase1/sdkconfig
GENCONFIG
CC build/bootloader/bootloader_support/src/bootloader_random.o
CC build/bootloader/bootloader_support/src/flash_encrypt.o
CC build/bootloader/bootloader_support/src/bootloader_sha.o
CC build/bootloader/bootloader_support/src/esp_image_format.o
CC build/bootloader/bootloader_support/src/flash_partitions.o
CC build/bootloader/bootloader_support/src/secure_boot_signatures.o
CC build/bootloader/bootloader_support/src/secure_boot.o
CC build/bootloader/bootloader_support/src/efuse.o
CC build/bootloader/bootloader_support/src/bootloader_flash.o
AR build/bootloader/bootloader_support/libbootloader_support.a
CC build/bootloader/log/log.o
AR build/bootloader/log/liblog.a
CC build/bootloader/spi_flash/spi_flash_rom_patch.o
AR build/bootloader/spi_flash/libspi_flash.a
CC build/bootloader/micro-ecc/micro-ecc/uECC.o
AR build/bootloader/micro-ecc/libmicro-ecc.a
CC build/bootloader/soc/esp32/rtc_clk.o
CC build/bootloader/soc/esp32/rtc_time.o
CC build/bootloader/soc/esp32/rtc_sleep.o
CC build/bootloader/soc/esp32/rtc_init.o
CC build/bootloader/soc/esp32/soc_memory_layout.o
CC build/bootloader/soc/esp32/cpu_util.o
CC build/bootloader/soc/esp32/rtc_pm.o
AR build/bootloader/soc/libsoc.a
CC build/bootloader/main/flash_qio_mode.o
CC build/bootloader/main/bootloader_start.o
C:/Dropbox/devs/ws/z-sdk/esp-idf/components/bootloader/subproject/main/bootloader_start.c: In function 'clock_configure':
C:/Dropbox/devs/ws/z-sdk/esp-idf/components/bootloader/subproject/main/bootloader_start.c:736:13: error: 'CONFIG_ESP32_DEFAULT_CPU_FREQ_MHZ' undeclared (first use in this function)
CONFIG_ESP32_DEFAULT_CPU_FREQ_MHZ == 240) {
C:/Dropbox/devs/ws/z-sdk/esp-idf/components/bootloader/subproject/main/bootloader_start.c:736:13: note: each undeclared identifier is reported only once for each function it appears in
C:/Dropbox/devs/ws/z-sdk/esp-idf/components/bootloader/subproject/main/bootloader_start.c:742:25: error: 'CONFIG_ESP32_XTAL_FREQ' undeclared (first use in this function)
clk_cfg.xtal_freq = CONFIG_ESP32_XTAL_FREQ;
C:/Dropbox/devs/ws/z-sdk/esp-idf/components/bootloader/subproject/main/bootloader_start.c: In function 'uart_console_configure':
C:/Dropbox/devs/ws/z-sdk/esp-idf/components/bootloader/subproject/main/bootloader_start.c:765:26: error: 'CONFIG_CONSOLE_UART_NUM' undeclared (first use in this function)
const int uart_num = CONFIG_CONSOLE_UART_NUM;
C:/Dropbox/devs/ws/z-sdk/esp-idf/components/bootloader/subproject/main/bootloader_start.c:799:27: error: 'CONFIG_CONSOLE_UART_BAUDRATE' undeclared (first use in this function)
const int uart_baud = CONFIG_CONSOLE_UART_BAUDRATE;
make[2]: *** [/c/Dropbox/devs/ws/z-sdk/esp-idf/make/component_wrapper.mk:229: bootloader_start.o] Error 1
make[1]: *** [/c/Dropbox/devs/ws/z-sdk/esp-idf/make/project.mk:391: component-main-build] Error 2
make: *** [/c/Dropbox/devs/ws/z-sdk/esp-idf/components/bootloader/Makefile.projbuild:39: /c/Dropbox/devs/ws/esp32/esp-phase1/build/bootloader/bootloader.bin] Error 2
Can you possibly paste the exact commands you used to perform the pull and sub-module fix up?
No problem.
Started by deleting the whole esp-idf directory at "C:\Dropbox\devs\ws\z-sdk\esp-idf"
Then in "C:\Dropbox\devs\ws\z-sdk" I ran:
Whole clone process went fine, no error messages.git clone --recursive https://github.com/espressif/esp-idf.git
I have a test I would like you to run please.
I am assuming you have a project sub-directory. I will assume it is called "XYZ"
In the directory called "XYZ" you will find files called "components", "sdkconfig" and "main" (and more).
I want you to do two things:
1. Replace the file called "sdkconfig" in your project directory with this one "https://github.com/espressif/esp-idf-te ... /sdkconfig"
2. Remove the directory called "build" in your project directory (it will be recreated)
when done, try and re-build all after having doing your "make menuconfig"
As always, back up your project before you attempt any suggestions offered by anyone.
tried the steps exactly, no difference.
Where my working environment differ a little bit is that the ./ws/esp32/projectX/main is essentially unused.
It contains the default component.mk and a main.c with a single
void dummy_function(void) { }
My main application is located in a ./ws/z-apps/projectX directory that contains:
blank default component.mk
various source and header files.
What is noticeable is that:
#1 every time I start with a full complete sdkconfig (9671 bytes), after make menuconfig it is 4971 bytes with no changes made
#2 the error always occurs at the same step in the compile process
#3 by manually adding the missing lines to sdkconfig I can get the compile to continue..
Not sure exactly how solved but deleted and re-cloned the idf, reinstalled the complete msys + toolchain, removed Eclipse completely and using separate editor, now working fine.
Glad you got it sorted out. For the record, it sounds like something we've seen happen when IDF can't find all the components, either because of IDF_PATH setting or because of something weird happened with the directory structure. Or if you have components in the project's "components" directory that have the same name as core IDF components (like 'esp32').
If a component in project's "component" directory matches with the esp's library of components, then the later one is removed from dependency list & from sdkconfig.
Thanks ESP_Angus for your hint.
Users browsing this forum: Google [Bot] and 256 guests
