about common_test_methods
sangk82
Postby sangk82 » Mon Mar 25, 2024 8:39 am
Hi.
I'm on Windows11, vscode esp-idf.
When I tried to run examples like ws_echo_server or https_server_simple, there are python files as pytest_ws_server_example.py, pytest_https_server_simple.py.
in that files,
import pytest
from common_test_methods import get_env_config_variable
from pytest_embedded import Dut
the problem is " common_test_methods ".
it can't find "common_test_methods" and causes error.
I installed commonmethods but it doesn't work.
how can I install or do something for this error.
thank you.
boaterly
Re: about common_test_methods
Postby boaterly » Wed May 01, 2024 10:21 pm
The common_test_methods module can be found in your IDF installation.
For 5.2.1 it can be found in: esp-idf-v5.2.1\tools\ci\python_packages
Sansveni
Postby Sansveni » Wed May 22, 2024 3:55 pm
I see common_test_methods.py in the directory you mentioned...what needs to be done to install this as a module?
Users browsing this forum: PetalBot and 3 guests
