Bug in header file ulp_riscv_gpio.h
cbaurtx
Postby cbaurtx » Mon Apr 01, 2024 11:20 am
Code: ulp_riscv_gpio.h Select all
static inline void ulp_riscv_gpio_output_level(gpio_num_t gpio_num, uint8_t level)
if (level) {
REG_SET_FIELD(RTC_GPIO_OUT_W1TS_REG, RTC_GPIO_OUT_DATA_W1TS, BIT(gpio_num));
} else {
REG_SET_FIELD(RTC_GPIO_OUT_W1TC_REG, RTC_GPIO_OUT_DATA_W1TS, BIT(gpio_num));
Code for if(level) and else is identical. Clearly one should be W1TC
ESP-IDF Version 5.1 used with ADF version 2.6
Can you point me to a working example using ESP32-S3 with the riscv ulp controlling an rtcio as output?
MicroController
Re: Bug in header file ulp_riscv_gpio.h
Postby MicroController » Mon Apr 01, 2024 9:47 pm
Luckily it's not.
MicroController
Postby MicroController » Tue Apr 02, 2024 8:32 pm
But... in fact, REG_WRITE should be used there instead of REG_SET_FIELD, like
        if (level) {
            REG_WRITE(RTC_GPIO_OUT_W1TS_REG, ((BIT(gpio_num) << RTC_GPIO_OUT_DATA_W1TS_S) & RTC_GPIO_OUT_DATA_W1TS_M));
        } else {
            REG_WRITE(RTC_GPIO_OUT_W1TC_REG, ((BIT(gpio_num) << RTC_GPIO_OUT_DATA_W1TC_S) & RTC_GPIO_OUT_DATA_W1TC_M));
Would be faster and, after all, W1TC and W1TS are write-only registers.
cbaurtx
Re: Bug in header file ulp_riscv_gpio.h (solved)
Postby cbaurtx » Thu Apr 04, 2024 8:13 pm
I was a complete fool, yes the code is not identical and it does work as intended.
MicroController
Postby MicroController » Thu Apr 04, 2024 8:57 pm
I wouldn't say that :)
RTC_GPIO_OUT_DATA_W1TS in the "else" branch is actually wrong - it only works because RTC_GPIO_OUT_DATA_W1TS and RTC_GPIO_OUT_DATA_W1TC happen to be the same value...
Users browsing this forum: ChatGPT-User and 5 guests
