littlefs panic when partition is full
owenjames
Postby owenjames » Tue Apr 02, 2024 1:28 am
I am using littlefs to store logs to internal flash and have been testing the behaviour when the littlefs partition is full. I expected a graceful failure of fopen() or fprintf() but I get a DivideByZero exception from lfs_alloc in the bowels of the library from fclose(). It seems that I need to leave 8K of unused space to avoid this. Am I missing some config?
ESP-IDF v5.1.2
litlefs v1.14.2
adokitkat
Re: littlefs panic when partition is full
Postby adokitkat » Mon Apr 15, 2024 11:27 am
Thank you for the report. We will investigate this. However it may be an issue on the LittleFS side. If so we will notify the maintainers.
bnp117
Postby bnp117 » Mon Apr 15, 2024 6:53 pm
@owenjames can you post the full log? I believe this is an upstream core littlefs issue (unexpected divide by zero); esp_littlefs should be reporting an appropriate error code. The log can help us raise an appropriate issue in https://github.com/littlefs-project/littlefs
owenjames
Postby owenjames » Tue Apr 16, 2024 1:45 am
Sorry, I don't have the log now but my notes show the exception occurs in lfs.c (when block_count is zero):
Code: Untitled.c Select all
static int lfs_alloc(lfs_t *lfs, lfs_block_t *block) {
// In order to keep our block allocator from spinning forever when our
// filesystem is full, we mark points where there are no in-flight
// allocations with a checkpoint before starting a set of allocations.
// If we've looked at all blocks since the last checkpoint, we report
// the filesystem as out of storage.
if (lfs->lookahead.ckpoint <= 0) {
LFS_ERROR("No more free space 0x%"PRIx32,
(lfs->lookahead.start + lfs->lookahead.next)
% lfs->cfg->block_count);
return LFS_ERR_NOSPC;
bnp117
Postby bnp117 » Tue Apr 16, 2024 11:14 pm
In this context,
block_count
is the number of blocks in the entire filesystem, not free ones remaining. In newer versions of littlefs, the
lfs_config.block_count
value can be set to 0 to be inferred from an existing filesystem; on mount
lfs.block_count
is then appropriately populated.
If you can get a fullstack trace, or other info, it would greatly help! Upstream littlefs does have exhaustion tests, and I cannot find a location by inspection where a DivideByZero could occur. Thanks!
Also, I just released esp_littlefs v1.14.3 that updates littlefs v2.9.0 to v2.9.1, incase that fixes anything.
bnp117
Postby bnp117 » Wed Apr 17, 2024 3:41 am
Based on huming2207 being able to reproduce it here: https://github.com/joltwallet/esp_littlefs/issues/183
I opened up a PR that may resolve the issue here: https://github.com/littlefs-project/littlefs/pull/966
Will update when it gets merged and and makes its way to esp_littlefs.
bnp117
Postby bnp117 » Wed Apr 17, 2024 6:15 pm
fixed in core littlefs v2.9.2, and subsequently in esp_littlefs v1.14.4
