Not able to perform OTA using ESP32 with AWS S3
chegewara
Re: Not able to perform OTA using ESP32 with AWS S3
Postby chegewara » Fri May 03, 2024 6:24 am
Im guessing this certificate is not bundled and you should try to add it or to use in your config
.cert_pem = NULL, <------------ here
https://www.amazontrust.com/repository/ ... 48-M03.pem,
Read this:
https://docs.espressif.com/projects/esp ... undle.html
Users browsing this forum: Baidu [Spider], DuckDuckGo [Bot], PerplexityBot, Qwantbot, Semrush [Bot] and 1 guest
