Partition table without factory partition
TypingRabbit
Postby TypingRabbit » Wed Feb 19, 2020 7:03 pm
in the current project I am currently trying to realize we need as much NVS memory as possible and as much memory as possible for each OTA partition.
Now my question is if there is anything to consider when simply removing the factory partition from the partition table "Factory app, two OTA definitions"?
Here is my current partition table:
# Espressif ESP32 Partition Table
# Name,     Type,   SubType,    Offset,     Size, Flags
nvs,        data,   nvs,        0x9000,     0xF3000,
otadata,    data,   ota,        0xFD000,    0x2000,
phy_init,   data,   phy,        0xFF000,    0x1000,
ota_0,      0,      ota_0,      0x100000,   0x180000,
ota_1,      0,      ota_1,      0x280000,   0x180000,
Many greetings
TypingRabbit
Re: Partition table without factory partition
Postby Sprite » Wed Feb 19, 2020 7:38 pm
If there is no factory app, the bootloader will normally just always boot from the active OTA app.
eriksl
Postby eriksl » Sat May 04, 2024 8:14 am
Currently it doesn't work:
[ 0%] Generating ../../partition_table/partition-table.bin
[ 0%] Built target _project_elf_src
[ 0%] Built target memory_ld
Error at line 6: Value 'factory' is not valid. Known keywords: ota, phy, nvs, coredump, nvs_keys, efuse, undefined, esphttpd, fat, spiffs, littlefs
Please check extra_partition_subtypes.inc file in build/config directory
Postby Sprite » Sun May 05, 2024 1:36 am
That's a different issue. Suggest you start your own post for that, and make sure you also post the partitions.csv file you have.
eriksl
Postby eriksl » Sun May 19, 2024 7:25 pm
Thanks for your help. It appeared to be a f*up of myself, fixed it. It works now.
I now even have OTA update over Bluetooth working, which was a bit of a challenge as the S3 doesn't have BT "classic" so no SPP support and even very little support for (large) streams of data. Also I must say the documentation of Nimble leaves a lot to be desired.
Users browsing this forum: Bing [Bot], Bytespider, DuckDuckGo [Bot], Qwantbot and 1 guest
