[SDK Release] ESP31B RTOS_SDK_V1.0.0_15_11_23
ESP_Faye
Postby ESP_Faye » Thu Dec 10, 2015 7:10 am
EDIT: Moderators note: despite the name, this SDK release is for ESP31B. Use esp-idf for ESP32 development.
ESP32_RTOS_SDK_V1.0.0_15_11_23 Release
Important Links
Here are the links for this SDK release (version ESP32_RTOS_SDK_V1.0.0_15_11_23):
  1. Download ESP32_RTOS_SDK_V1.0.0_15_11_23
  2. Download ESP32 Related Documentation
  3. Bug Bounty Program
Have fun!
_______________________________________________________
ESP32_RTOS_SDK_V1.0.0_15_11_23发布
相关下载
    以下是最新SDK的相关下载链接 (版本 ESP32_RTOS_SDK_V1.0.0_15_11_23):
  1. ESP32_RTOS_SDK_V1.0.0_15_11_23 下载链接
  2. ESP32 文档下载链接
  3. 您可以继续参与 Bug Bounty 计划
感谢您对 ESP32 的关注!
zeroday
Re: [SDK Release] ESP32_RTOS_SDK_V1.0.0_15_11_23
Postby zeroday » Fri Dec 11, 2015 2:38 am
any info about non-os sdk?
captain_morgan
Postby captain_morgan » Mon Dec 14, 2015 2:24 am
Is there API documentation similar to 2C-ESP8266__SDK__Programming Guide__EN_v1.4.pdf for the ESP8266? I've been searching quite a bit and cannot seem to find anything.
ESP_Faye
Postby ESP_Faye » Mon Dec 14, 2015 8:14 am
ESP32 SDK is RTOS SDK, not non-OS SDK.
Here is the ESP32_RTOS_SDK_API_Reference.
Thanks for your interest in ESP32 !
ESP32__RTOS_SDK_API Reference__v1.0.0.zip
(327.49 KiB) Downloaded 316 times
captain_morgan
Postby captain_morgan » Tue Dec 15, 2015 3:50 pm
Fantastic, this is exactly what I was after. Thank you.
c.dicaprio
Postby c.dicaprio » Tue Dec 15, 2015 5:59 pm
Hello to all,
I hope this can be usefull to other.
Following the instruction on the GitHub, about how to install the SDK, on my Ubuntu 15, I found this:
1. On "Tollchain:Step 5"
to solve this error:
   checking for GNU libtool >= 1.5.26... no
   configure: error: could not find GNU libtool >= 1.5.26
I installed libtool-bin with this command:
"sudo apt-get install libtool-bin"
2. On "Project template Compile:Step 6" before the commands:
   make clean
   make
I needed to execute:
   cd ~/Workspace/project_template/
And, I really don't know how, following the instruction, I created a directory named "-p". :o
By the way, if this happen you can execute this commands, changing the inode number however:
userx@ubuntu:~/Workspace$ ls -a
.  ..  ESP32_BIN  ESP32_RTOS_SDK  –p  project_template
userx@ubuntu:~/Workspace$ ls -li
total 16
311435 drwxrwxr-x  2 userx userx 4096 Dec 15 08:40 ESP32_BIN
311079 drwxrwxr-x 10 userx userx 4096 Dec 15 08:35 ESP32_RTOS_SDK
311433 drwxrwxr-x  2 userx userx 4096 Dec 15 08:35 –p
960537 drwxrwxr-x  6 userx userx 4096 Dec 15 08:40 project_template
userx@ubuntu:~/Workspace$ find . -inum 311433 -delete
ESP32_BIN  ESP32_RTOS_SDK  project_template
Regards
Clemente
Postby rudi ;-) » Tue Dec 15, 2015 8:12 pm
c.dicaprio wrote:..
Regards
Clemente
you are welcome
viewtopic.php?f=2&t=26
yes - had the same -p directory :)
the -p direcory comes from the Step 4 "Project Template compiling"
mkdir –p ~/Workspace/ESP32_BIN
usually and normal the command is ok.
http://manpages.ubuntu.com/manpages/wil ... dir.1.html
btw
the "parents option" --p makes a "--p" directory :D
c.dicaprio
Postby c.dicaprio » Tue Dec 15, 2015 8:54 pm
you are welcome
Thanks Rudy! I didn't see it...
Regards
Clemente
Ritesh
Contact:
Postby Ritesh » Sat Oct 22, 2016 11:06 am
I have one ESP32 Demo Development kit in which 1 MB SPI flash based ESP32 module is attached. I have downloaded ESP32 RTOS SDK 2.0.0 version which is not working as board is going to reset due to some reason.
SO, will this ESP32 RTOS SDK 1.0.0 be worked for my ESP32 based kit or its only for ESP31 module?
Please let me know if anyone has idea for that.
Regards,
Ritesh Prajapati
Regards,
Ritesh Prajapati
WiFive
Postby WiFive » Sat Oct 22, 2016 11:10 am
Ritesh wrote:Hi,
Regards,
Ritesh Prajapati
Only esp-idf is for esp32. All RTOS SDK is for esp31. What board you have? I think most are 4MB?
