ESP-IDF setup error in vscode with ESP-IDF extension
jhlee1
Postby jhlee1 » Wed Jun 12, 2024 5:34 am
Install ESP-IDF: v5.2.2
VSCode: v1.90.0
ESP-IDF Extension: v1.7.1
I try to install ESP-IDF stable version(v5.2.2) in VSCode
But, I face error message when install it.
ESP-IDF was install in directory, but setup in vscode with esp-idf extension is not completed
Steps to reproduce.
1. Install VSCode and ESP-IDF Extension
2. write "ESP-IDF: Configure ESP-IDF extension" in command palette and click
3. click "EXPRESS"
4. Select ESP-IDF v5.2.2 and install
When complete install, face error message.
setup error message.png (24.53 KiB) Viewed 9874 times
When creating an example in VSCode("ESP-IDF:Show Example Project" in the command palette), the ESP-IDF version v5.2.2 is not activated, and when checking the USE EXISTING SETUP item in "ESP-IDF: Configure ESP-IDF extension", v5.2.2 does not appear.
How can I complete setup?
Thanks.
bignacio
Re: ESP-IDF setup error in vscode with ESP-IDF extension
Postby bignacio » Fri Jun 14, 2024 4:56 am
In Visual Studio Code select menu View then click Command Palette... and type ESP-IDF: Doctor Command to generate a report of your environment configuration and it will be copied in your clipboard to paste anywhere.
Check log file which can be obtained from:
Windows: %USERPROFILE%\.vscode\extensions\espressif.esp-idf-extension-VERSION\esp_idf_vsc_ext.log
Linux & MacOSX: $HOME/.vscode/extensions/espressif.esp-idf-extension-VERSION/esp_idf_vsc_ext.log
Could you share this information to find out the error ?
jhlee1
Postby jhlee1 » Mon Jun 17, 2024 10:39 am
I found below in log file you mentioned:
Error: Command failed: \"d:\\esp\\espressif\\tools\\idf-python\\3.11.2\\python.exe\" \"d:\\esp\\v5.2.2\\esp-idf\\tools\\idf_tools.py\" install-python-env\nERROR: Python environment is set to d:\\esp\\espressif\\python_env\\idf5.2_py3.11_env which was generated for ESP-IDF v5.2.2 instead of the current 5.2. The issue can be solved by (1) removing the directory and re-running the install script, or (2) unsetting the IDF_PYTHON_ENV_PATH environment variable, or (3) re-runing the install script from a clean shell where an ESP-IDF environment is not active.
I tried the first method suggested in the log, and the installation appears to have completed normally in VSCode.
esp-idf_v5.2.2 settup.png (13.48 KiB) Viewed 9642 times
It has been resolved, but I think the same problem appears to occur even if v5.2.2 is additionally installed in an environment where the v5.2 version is installed.
jhlee1
Postby jhlee1 » Tue Jun 18, 2024 12:31 am
There is only one difference between IDF setup success and failure.
It just need to add `idf_version.txt` in <IDF_TOOLS_PATH>\python_env\idf5.2_py3.11_env before download or search ESP-IDF setup.
Content of `idf_version.txt` file is `5.2`.
bignacio
Postby bignacio » Fri Jun 21, 2024 8:15 am
We should have a fix in this vsix installer and it will be part of the next v1.8.0 release.
You can try by uninstall your current esp-idf vscode extension and install the vsix from the link with Install from VSIX command in vscode.
