There are SPI_USER_REG (0x1C) flags SPI_WR_BYTE_ORDER and SPI_RD_BYTE_ORDER, switching endianess of Tx and Rx data.
When SPI MISO stream is following:
from left to right: 00 49 4A F0 80 00, with default settings SPI transaction field rx_buffer gets MISO data exactly in the order from left to right.
Which effect will cause SPI_RD_BYTE_ORDER when enabled?
Does it depend on DMA or not?
How to enable these options in spi master driver?
SPI_USER_REG byte order flags: what do they exactly do?
powerbroker
Re: SPI_USER_REG byte order flags: what do they exactly do?
hi
https://github.com/espressif/esp-idf/bl ... i_master.h
spi_device_interface_config.flags
#define SPI_DEVICE_TXBIT_LSBFIRST (1<<0) ///< Transmit command/address/data LSB first instead of the default MSB first
#define SPI_DEVICE_RXBIT_LSBFIRST (1<<1) ///< Receive data LSB first instead of the default MSB first
#define SPI_DEVICE_BIT_LSBFIRST (SPI_DEVICE_TXBIT_LSBFIRST|SPI_DEVICE_RXBIT_LSBFIRST) ///< Transmit and receive LSB first
powerbroker
so, byte order remains the same, and bits within bytes get reversedhi
spi_device_interface_config.flagsCode: Select all
#define SPI_DEVICE_TXBIT_LSBFIRST (1<<0) ///< Transmit command/address/data LSB first instead of the default MSB first #define SPI_DEVICE_RXBIT_LSBFIRST (1<<1) ///< Receive data LSB first instead of the default MSB first #define SPI_DEVICE_BIT_LSBFIRST (SPI_DEVICE_TXBIT_LSBFIRST|SPI_DEVICE_RXBIT_LSBFIRST) ///< Transmit and receive LSB first
thanks
