Two questions: first, I am sending a small (12 byte) struct from one ESP32 to another, and returning an ack. The exchange frequently fails. The esp_now_send() never fails, and always returns ESP_OK. However, the send callback returns failure most of the time. When I check the status in the callback, it's either ESP_NOW_SEND_SUCCESS (occasionally) or ESP_NOW_SEND_FAIL (usually).
In esp_now.h, there are a lot of specific error codes for different conditions. How do I get access to the error code causing my failure? The send always returns success, and then the failed callback doesn't give any useful information.
Second question: I'm hosting a small web site for device/sensor status (sent via SSE/Javascript), as well as OTA updates and Webserial. I suspect there's too much TCP/HTTP traffic going out and the ESPNOW packets are squashed. Are there any good ways to broker traffic between ESPNOW and everything else? Obviously I can shut off the web service but I would like to have both. And I can switch ESPNOW to raw UDP or TCP, but I would like the two devices to be able to communicate even when they are not connected to wifi (the devices will go on a boat where there may sometimes be wifi and frequently there will not but they still need to communicate). I could switch to TCP when connected to a network and switch back to ESPNOW otherwise, but that's a lot of additional work. It would be nice if they could coexist.
Environment: VS Code + PIO + Arduino.
how to see ESPNOW send error code?
MicroController
Re: how to see ESPNOW send error code?
Seems like that's all the information you get. ESP-NOW works asynchronously, i.e. you enqueue data to be sent via esp_now_send(), transmission and re-transmission happen 'in the background', and you are notified via callback about the outcome when it's done.The esp_now_send() never fails, and always returns ESP_OK. However, the send callback returns failure most of the time. When I check the status in the callback, it's either ESP_NOW_SEND_SUCCESS (occasionally) or ESP_NOW_SEND_FAIL (usually).
If you get ESP_NOW_SEND_FAIL in the callback, https://docs.espressif.com/projects/esp ... p-now-data applies:
Several reasons can lead to ESP-NOW fails to send data. For example, the destination device does not exist; the channels of the devices are not the same; the action frame is lost when transmitting on the air, etc.
I don't think that's the issue.I suspect there's too much TCP/HTTP traffic going out and the ESPNOW packets are squashed.
Thanks, that was helpful. It looks like my problem is more about channel selection on my mesh network.
MicroController
IIRC, ESP-NOW uses whatever channel the WiFi is currently using, so yes, controlling the WiFi channel is required for successful ESP-NOW communication.It looks like my problem is more about channel selection on my mesh network.
Users browsing this forum: PerplexityBot and 2 guests
