Freertos不兼容,已经配置添加了V8.00版本,还是不兼容,目前用的idf5.2adf最新
yuanjie
Postby yuanjie » Wed Jul 17, 2024 3:12 pm
[149/570] Building C object esp-idf/wifi_provisioning/CMakeFiles/__idf_wifi_provisioning.dir/src/manager.c.obj
HINT: You are maybe using pre FreeRTOS V8.0.0 data types. The backward compatibility of such data types is no longer enabled by default. Please turn on CONFIG_FREERTOS_ENABLE_BACKWARD_COMPATIBILITY explicitly to use such data types.
ninja failed with exit code 1, output of the command is in the /home/yuan/esp/esp-adf/examples/get-started/WiFi_Walkie/build/log/idf_py_stderr_output_2122496 and /home/yuan/esp/esp-adf/examples/get-started/WiFi_Walkie/build/log/idf_py_stdout_output_2122496
William
Re: Freertos不兼容,已经配置添加了V8.00版本,还是不兼容,目前用的idf5.2adf最新
Postby William » Fri Aug 23, 2024 8:22 am
你可以在 $ADF_PATH/idf_patches 中打对应idf版本的补丁到 $IDF_PATH 解决该问题。
