This is supposed to look like this:
Code: Untitled.txt Select all
Size Summary idf.py size
This output provides a summary of the statically-allocated memory for different memory types in the firmware binary:
$ idf.py size
Memory Type Usage Summary
┃ Memory Type/Section ┃ Used [bytes] ┃ Used [%] ┃ Remain [bytes] ┃ Total [bytes] ┃
│ Flash Code │ 80666 │ 2.41 │ 3261638 │ 3342304 │
│ .text │ 80666 │ 2.41 │ │ │
│ IRAM │ 51835 │ 39.55 │ 79237 │ 131072 │
│ .text │ 50807 │ 38.76 │ │ │
│ .vectors │ 1027 │ 0.78 │ │ │
│ Flash Data │ 38224 │ 0.91 │ 4156048 │ 4194272 │
│ .rodata │ 37968 │ 0.91 │ │ │
│ .appdesc │ 256 │ 0.01 │ │ │
│ DRAM │ 11236 │ 6.22 │ 169500 │ 180736 │
│ .data │ 8988 │ 4.97 │ │ │
│ .bss │ 2248 │ 1.24 │ │ │
│ RTC SLOW │ 24 │ 0.29 │ 8168 │ 8192 │
│ .rtc_slow_reserved │ 24 │ 0.29 │ │ │
Total image size: 179712 bytes (.bin may be padded larger)Code: Untitled.txt Select all
Total sizes:
Used static DRAM: 38564 bytes ( 142172 remain, 21.3% used)
.data size: 15692 bytes
.bss size: 22872 bytes
Used static IRAM: 96414 bytes ( 34658 remain, 73.6% used)
.text size: 95387 bytes
.vectors size: 1027 bytes
Used Flash size : 1280471 bytes
.text: 1045331 bytes
.rodata: 234884 bytes
Total image size: 1392577 bytes (.bin may be padded larger)Thanks
