ESP32 LittleFS and the Directory Object 'Dir' . Is it missing?
arjen1
Postby arjen1 » Sat Aug 10, 2024 10:29 pm
Dear Forum
Trying to port some Esp8266 software to ESP32.
The issue I have is with LittleFS. In the esp8266 I use a type 'Dir', as in
  Dir dir = LittleFS.openDir(directory);
This object then has some properties like filesize, filecreationtime, filename and whether it is directory or a file.
However, when trying to compile this code for ESP32 I get an error 'error: 'Dir' has not been declared'.
And it seems that the info structure is also not defined for esp32
  FSInfo fs_info_webserver;
  LittleFS.info(fs_info_webserver);
I have searched for 2 hours now, could not find the solution.
What am i missing? The littlefs lib is fixed in the arduino Ide is it not? Or do i have to install another library?
Your input will be appreciated.
lbernstone
Re: ESP32 LittleFS and the Directory Object 'Dir' . Is it missing?
Postby lbernstone » Sat Aug 10, 2024 10:47 pm
FS is implemented in a different way on ESP32. The underlying OS is posix-style, so directories are just a different type of file. See the example for more details on how to implement directory scanning and getting filesystem info.
arjen1
Postby arjen1 » Sat Aug 10, 2024 11:03 pm
Thanks. I did find this example earlier but was hoping life would be easy :|
I'll look into that and rewrite the bits that differ....
Users browsing this forum: Amazon [Bot], Baidu [Spider] and 3 guests
