Arduino serial monitor not showing any output when ESP32-S3 connected to USB Port
karunt
Postby karunt » Sun Aug 11, 2024 2:21 pm
Using Arduino IDE 2.3.2 on Windows 11 to upload the following sketch to an Adafruit Qualia ESP32-S3 board:
#include <Arduino_GFX_Library.h>
void setup() {
  Serial.begin(9600);
void loop() {
  Serial.println("hello");
  delay(1000);
USB CDC On Boot settings in Arduino set to
Enabled
After successful upload, the Arduino serial monitor doesn't show any output at all besides something like
15:04:15.106 -> ESP-ROM:esp32s3-20210327
I was told to manually press the Reset button on the board after uploading the sketch. But if I do that, the serial monitor shows the following error:
Port monitor error: command 'open' failed: Serial port not found. Could not connect to COM3 serial port.
Posted this question on Arduino forum also, but nobody has been able to help me find a solution to the problem. Without a functioning serial monitor, it's nearly impossible to see if my board and code perform the way they're supposed to. Is there anything else I need to do in Arduino to make ESP32-S3 based boards work? Thank you.
aliarifat794
Re: Arduino serial monitor not showing any output when ESP32-S3 connected to USB Port
Postby aliarifat794 » Sun Aug 11, 2024 3:23 pm
You can try to use a different USB Port.
karunt
Postby karunt » Mon Aug 12, 2024 5:12 am
My laptop has 2 USB ports. Used both. Same result.
Users browsing this forum: Perplexity-User, Qwantbot and 3 guests
