ESP32S3 USB OTG switch to Low Speed
analoglamb
Postby analoglamb » Wed Aug 14, 2024 10:18 am
1. How to switch the usb otg speed from full speed to low speed?
2. esp32s3's USB only support OTG, but in the pinout there is no usb id pin, why? I want to use USB ID pin to determine esp32s3 role. How to solve it?
ESP32 Chip, Module, Development board! Go: [url]https://analoglamb.com/[/url]
aliarifat794
Re: ESP32S3 USB OTG switch to Low Speed
Postby aliarifat794 » Wed Aug 14, 2024 5:50 pm
On the ESP32-S3, D- and D+ should be tied to GPIO19 and GPIO20. More here: viewtopic.php?t=26030
chegewara
Postby chegewara » Thu Aug 15, 2024 8:37 am
The easiest way IIRC is to swap D+ and D- pins, but there is also some software way (when you configure usb device code).
analoglamb
Postby analoglamb » Fri Aug 16, 2024 2:44 am
How to switch the usb otg speed from full speed to low speed? @espressif
Postby Sprite » Fri Aug 16, 2024 3:40 am
You would normally do that in the device stack, which in our case is TinyUSB. I don't think TinyUSB has proper support for this, though, as USB low speed isn't really used anymore when you also can do full speed.
analoglamb
Postby analoglamb » Fri Aug 16, 2024 4:04 am
chegewara
Postby chegewara » Mon Aug 19, 2024 3:41 pm
Screenshot from 2024-08-19 17-39-55.png (70.33 KiB) Viewed 1834 times
Users browsing this forum: ChatGPT-User, YisouSpider and 0 guests
