Compiling ESP32-C2 Arduino lib
themindfactory
Postby themindfactory » Thu Sep 19, 2024 3:35 am
I am compiling the ESP32-C2 library for Arduino, once compiled I am unsure where all the files are I need to move into my Arduino folders.
I am compiling in Linux, and moving them to a Windows 10 machine.
I see a folder called out that has tools in it, I see also a folder called components/Arduino that looks like we need them, however where is the RISC-V GCC compiler added?
Anyone have instructions on such a data move?\
I am also using 'python3 app.py' to do the setup and compiling.
Richard.
lbernstone
Re: Compiling ESP32-C2 Arduino lib
Postby lbernstone » Thu Sep 19, 2024 6:19 pm
You need the entirety of the tools/esp32-arduino-libs folder. You should ensure that you are compiling the exact same version of arduino-esp32 as what is in your Arduino sketch folder, so that when you run get.py (or exe) your gcc binaries will match.
In recent versions of the code, I think C2 is included, but hidden.
themindfactory
Postby themindfactory » Thu Sep 19, 2024 8:42 pm
OK interesting, now I have un-hidden it, and I see the C2 module, now when it compiles I get:
  File "esptool.py", line 37, in <module>
  File "esptool\__init__.py", line 1064, in _main
  File "esptool\__init__.py", line 888, in main
  File "esptool\cmds.py", line 977, in elf2image
  File "esptool\bin_image.py", line 1083, in __init__
FileNotFoundError: [Errno 2] No such file or directory: 'C:\\Users\\Richard\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-b6b4727c58\\esp32c2\\bin\\bootloader_qio_60m.elf'
[2320] Failed to execute script 'esesptool.py v4.6
ptool' due to unhandled exception!
exit status 1
Compilation error: exit status 1
When I look into that folder I find the esp32c2 folder under C:\Users\Richard\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58 is missing.
lbernstone
Postby lbernstone » Fri Sep 20, 2024 12:07 am
If you are not familiar with building frameworks, you should use the lib builder with the -t and -c options.
I would recommend using the manual install instead of board manager so your changes don't get overwritten.
themindfactory
Postby themindfactory » Fri Sep 20, 2024 12:31 am
I did use lib-builder, I will see what the -t and -c entail... when it ran ./build.py it used what ever args it needed at the time I will revisit this and see....
R.
themindfactory
Postby themindfactory » Fri Sep 20, 2024 12:35 am
It did a -t esp32c2 and a -D default
also it was build.sh not .py :-)
-c where should you point this to? I think when I installed Arduino to the windows machine the Arduino folder in Documents was empty and I think the same for the $HOME/Arduino on Linux....
R.
lbernstone
Postby lbernstone » Fri Sep 20, 2024 4:33 pm
From manual installation instructions:
Screenshot from 2024-09-20 06-32-23.png (71.36 KiB) Viewed 7692 times
themindfactory
Postby themindfactory » Tue Sep 24, 2024 4:19 pm
I cloned with git as it states in the docs, I make the c2 not hidden, I can see the new hardware directory show up in Arduino IDE.. however still get the error.
No such file or directory: 'C:\\Users\\Richard\\Documents\\Arduino\\hardware\\espressif\\esp32\\tools\\esp32-arduino-libs\\esp32c2\\bin\\bootloader_qio_60m.elf'
All ESPs are there in C:\Users\Richard\Documents\Arduino\hardware\espressif\esp32\tools\esp32-arduino-libs
see attached image
but no C2
R
themindfactory
Postby themindfactory » Tue Sep 24, 2024 4:50 pm
Thanks to all that helped I have now figured it all out and its compiling just fine!
R.
lbernstone
Postby lbernstone » Tue Sep 24, 2024 4:55 pm
I was incorrect. You will indeed need to compile the sdk libraries for esp32c2. You can then move your compiled esp32c2 folder into the location you showed in the previous post. Note that it is important that your idf/arduino versions match up (v3.0.5/ 5.1.4)- it is best to get to the exact versions used by the arduino-esp32 team.
Users browsing this forum: Baidu [Spider], ChatGPT-User and 3 guests
