UDA1334 i2s DAC with ESP32 - sketch too big
clovisf
Postby clovisf » Wed Oct 23, 2024 2:23 pm
Code: Untitled.txt Select all
I am trying to implement a web radio streaming device with ESP32 (DEVKITV1 from Aliexpress) and UDA1334A DAC. The problem is that when compiling in the Arduino IDE (2.3.3 nightly) I get the "sketch too big" error:
[quote]Sketch uses 1356645 bytes (103%) of program storage space. Maximum is 1310720 bytes. [/quote]
The sketch from this source https://electropeak.com/learn/interfacing-uda1334a-i2s-stereo-decoder-module-with-esp32/ is actually garbage, does not even compile. I made it try to compile (with the too big error) by adding the missing "()" in every single function.
The sketch from this source https://how2electronics.com/simple-esp32-internet-web-radio-with-oled-display/ actually tries to compile (gets the too big error), I even stripped it from the display part to try and save space.
In the Arduino IDE I tried to select both "uPesy ESP32 Wroom DEVkit" and "DO IT ESP32 DEVkit V1" as boards, no difference (still get the "sketch too big" error).
Any ideas as to why a sketch supposedly working (from a tutorial) does not compile?
EDIT: This is the full code that tries to compile (but still is flagged as too big of a sketch):
#include "Arduino.h"
#include "Audio.h"
#include
#include
//Digital I/O used  //Makerfabs Audio V2.0
#define I2S_DOUT 27
#define I2S_BCLK 26
#define I2S_LRC 25
//SSD1306
#define MAKEPYTHON_ESP32_SDA 4
#define MAKEPYTHON_ESP32_SCL 5
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET -1    // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
//Button
const int Pin_vol_up = 39;
const int Pin_vol_down = 36;
const int Pin_mute = 35;
const int Pin_previous = 15;
const int Pin_pause = 33;
const int Pin_next = 2;
Audio audio;
const char *ssid = "Alexahome";
const char *password = "loranthus";
struct Music_info
    String name;
    int length;
    int runtime;
    int volume;
    int status;
    int mute_volume;
} music_info = {"", 0, 0, 0, 0, 0};
int volume = 21;
int mute_volume = 0;
int runtime = 0;
int length = 0;
String stations[] = {
    "0n-80s.radionetz.de:8000/0n-70s.mp3",
    "mediaserv30.live-streams.nl:8000/stream",
    "www.surfmusic.de/m3u/100-5-das-hitradio,4529.m3u",
    "stream.1a-webradio.de/deutsch/mp3-128/vtuner-1a",
    "mp3.ffh.de/radioffh/hqlivestream.aac", //  128k aac
    "www.antenne.de/webradio/antenne.m3u",
    "listen.rusongs.ru/ru-mp3-128",
    "edge.audio.3qsdn.com/senderkw-mp3",
    "macslons-irish-pub-radio.com/media.asx"};
int station_index = 0;
int station_count = sizeof(stations) / sizeof(stations[0]);
void setup()
    //IO mode init
    pinMode(Pin_vol_up, INPUT_PULLUP);
    pinMode(Pin_vol_down, INPUT_PULLUP);
    pinMode(Pin_mute, INPUT_PULLUP);
    pinMode(Pin_previous, INPUT_PULLUP);
    pinMode(Pin_pause, INPUT_PULLUP);
    pinMode(Pin_next, INPUT_PULLUP);
    //Serial
    Serial.begin(115200);
    //LCD
    Wire.begin(MAKEPYTHON_ESP32_SDA, MAKEPYTHON_ESP32_SCL);
    // SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
    if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3C))
    { // Address 0x3C for 128x32
        Serial.println(F("SSD1306 allocation failed"));
        for (;;)
            ; // Don't proceed, loop forever
    display.clearDisplay();
    logoshow();
    //connect to WiFi
    Serial.printf("Connecting to %s ", ssid);
    WiFi.begin(ssid, password);
    while (WiFi.status() != WL_CONNECTED)
        delay(500);
        Serial.print(".");
    Serial.println(" CONNECTED");
    lcd_text("Wifi CONNECT");
    //Audio(I2S)
    audio.setPinout(I2S_BCLK, I2S_LRC, I2S_DOUT);
    audio.setVolume(21); // 0...21
    open_new_radio(stations[station_index]);
uint run_time = 0;
uint button_time = 0;
void loop()
    audio.loop();
    print_song_time();
    //Display logic
    if (millis() - run_time > 1000)
        run_time = millis();
        display_music();
    //Button logic
    if (millis() - button_time > 300)
        if (digitalRead(Pin_next) == 0)
            Serial.println("Pin_next");
            if (station_index  0)
                station_index--;
            else
                station_index = station_count - 1;
            button_time = millis();
        if (digitalRead(Pin_vol_up) == 0)
            Serial.println("Pin_vol_up");
            if (volume  0)
                volume--;
            audio.setVolume(volume);
        if (digitalRead(Pin_mute) == 0)
            Serial.println("Pin_mute");
            if (volume != 0)
                mute_volume = volume;
                volume = 0;
            else
                volume = mute_volume;
        if (digitalRead(Pin_pause) == 0)
            Serial.println("Pin_pause");
            audio.pauseResume();
    //Serial logic
    if (Serial.available())
        String r = Serial.readString();
        r.trim();
        if (r.length() > 5)
            audio.stopSong();
            open_new_radio(r);
        else
            audio.setVolume(r.toInt());
void print_song_time()
    runtime = audio.getAudioCurrentTime();
    length = audio.getAudioFileDuration();
void open_new_radio(String station)
    audio.connecttohost(station);
    Serial.println("**********start a new radio************");
void display_music()
    int line_step = 24;
    int line = 0;
    char buff[20];
    sprintf(buff, "RunningTime:%d",runtime);
    display.setTextSize(1);              // Normal 1:1 pixel scale
    display.setTextColor(SSD1306_WHITE); // Draw white text
    display.setCursor(0, line); // Start at top-left corner
    display.println(stations[station_index]);
    line += line_step * 2;
    display.println(buff);
    line += line_step;
    display.display();
void logoshow(void)
    display.setTextSize(2);              // Normal 1:1 pixel scale
    display.setCursor(0, 0);             // Start at top-left corner
    display.println(F("My ESP32"));
    display.setCursor(0, 20); // Start at top-left corner
    display.println(F("WEB` RADIO"));
    display.setCursor(0, 40); // Start at top-left corner
    display.println(F(""));
    display.display();
    delay(2000);
void lcd_text(String text)
    display.println(text);
    display.display();
    delay(500);
// optional
void audio_info(const char *info)
    Serial.print("info        ");
    Serial.println(info);
void audio_id3data(const char *info)
{ //id3 metadata
    Serial.print("id3data     ");
void audio_eof_mp3(const char *info)
{ //end of file
    Serial.print("eof_mp3     ");
void audio_showstation(const char *info)
    Serial.print("station     ");
void audio_showstreaminfo(const char *info)
    Serial.print("streaminfo  ");
void audio_showstreamtitle(const char *info)
    Serial.print("streamtitle ");
void audio_bitrate(const char *info)
    Serial.print("bitrate     ");
void audio_commercial(const char *info)
{ //duration in sec
    Serial.print("commercial  ");
void audio_icyurl(const char *info)
{ //homepage
    Serial.print("icyurl      ");
void audio_lasthost(const char *info)
{ //stream URL played
    Serial.print("lasthost    ");
void audio_eof_speech(const char *info)
    Serial.print("eof_speech  ");
horace99
Re: UDA1334 i2s DAC with ESP32 - sketch too big
Postby horace99 » Sun Oct 27, 2024 9:20 am
try changing the Partition scheme
click Tools>Board select ESP32 Dev Board under Partition Scheme select Huge App
Users browsing this forum: ChatGPT-User, Google [Bot] and 0 guests
