ESP32-S3 IO47 and IO48 as 1.8V UART?
iwanttolearn
Hi all! I've seen in the documentation of ESP32-S3-WROOM-1 that IO47 and IO48 pins on modules with PSRAM are set to 1.8V logic. Is it possible to do the same in modules without PSRAM, and then use these pins for UART connection to a GSM module that works at 1.8V?
aliarifat794
Re: ESP32-S3 IO47 and IO48 as 1.8V UART?
For modules without PSRAM, you would likely need to provide an external 1.8V regulator or a level shifter
Users browsing this forum: Bytespider and 3 guests
