Hello community,
We are exploring ESP32C3 for our DAQ application where we want to install the ESP32C3 on a high vibration surface for the entire lifespan of this DAQ. The vibration PSD shall be in range of 0.01G^2/Hz for 10Hz to 3000Hz range. Which is significant if not high vibration for crystal based oscillators.
Kindly guide if we can simply swap the 40Mhz crystal with a MEMS Oscillator for improved immunity to the external vibrations.
Regards.
Can we interface a 40Mhz MEMS Oscillator to the ESP32C3
chubs-forever
chubs-forever
Re: Can we interface a 40Mhz MEMS Oscillator to the ESP32C3
Anyone, any update, any feedback, any experience of interfacing Oscillator instead of crystal with the ESP32 chips?
morgana2313
We connected a SP32-S3R8 to a DSC1001DL5-040.0000 (MEMS XTAL ±10ppm) also because of high-vibration environment. Everything seems to work OK, except for the wifi.
morgana2313
The problem with wifi and MEMS oscillators turns out to be phase-jitter. The SiT5001 is a MEMS oscillator with low phase jitter that works with wifi when connected to an esp32s3: https://www.sitime.com/products/tcxos/sit5001We connected a SP32-S3R8 to a DSC1001DL5-040.0000 (MEMS XTAL ±10ppm) also because of high-vibration environment. Everything seems to work OK, except for the wifi.
Users browsing this forum: Qwantbot and 4 guests
