ESP32WROOM32 did NOT Run until I sent something to Serial.
drwho30
Postby drwho30 » Mon Nov 11, 2024 5:59 pm
Hi! I'm using Arduino IDE v2.3.3 - ESP32 Dev Module - esp32 by Espressif Systems v3.0.7
my board did NOT run until I sent something to Serial then it start booting and run normal.
i need help auto run please! Thanks
here booting info that i got
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0030,len:4832
load:0x40078000,len:16460
load:0x40080400,len:4
load:0x40080404,len:3504
entry 0x400
My code:
  String str_Rec;
  int pos_Equal;
  bool DI1 = true;
  String pointName;
  String pointValue;
  String str_Send;
void setup() {
  Serial.setTimeout(200); // timeOut 200 ms
  Serial.begin(115200, SERIAL_8N1);
  delay(3000);
void loop() {
  if (Serial.available() > 0)  // reply only if you receive data:
    str_Rec = Serial.readString();
    pos_Equal = str_Rec.indexOf("=?");
    if (pos_Equal != -1)
      pointName = str_Rec.substring(0, pos_Equal);
      if (DI1==true)
        str_Send = pointName + "=" + "ON";
        DI1 = !DI1;
      else
        str_Send = pointName + "=" + "OFF";
        DI1 = !DI1;
      Serial.println(str_Send);
  delay(1);
Users browsing this forum: meta-externalagent and 2 guests
