Smart programmable Multi-Sensor with JavaScript support
genemars
Postby genemars » Tue Nov 26, 2024 5:51 pm
In the following article I illustrate in a few steps how to build a smart multi-sensor with ESP32-C3/S3 (Mini/Zero) and HomeGenie Mini firmware.
The device allows you to automate actions with simple preset commands and based on specific times/dates, or following events (e.g.: "motion detected").
The device is directly programmable with JavaScript!
The article also contains an example of how it is possible with just 4 lines of code have the device send a WhatsApp/Telegram notification every time motion is detected.
You will also find a sample video showing the functionality of devices equipped with HomeGenie Mini firmware, that can communicate with each other and other external services and devices.
In the download section at the bottom of the page there is also the possibility to download the Gerber file to print the PCB and 3MF file for printing the casing via 3d printer.
HomeGenie Mini Smart Sensor
Gene.
