RSQRT on ESP32
alex000090
RSQRT on ESP32
Postby alex000090 » Tue Dec 24, 2024 9:11 am
Dear all,
Could you help me, is there an RSQRT (single precision) hardware or software function in ESP-IDF? I can't find information about it.
nopnop2002
Contact:
Re: RSQRT on ESP32
Postby nopnop2002 » Wed Dec 25, 2024 8:50 am
You can use these in esp-idf.
#include <stdio.h>
#include <math.h>
void app_main()
    double dx = 2.0;
    double da = sqrt(dx);
    float fx = 2.0;
    float fa = sqrt(fx);
    fa = sqrtf(fx);
    long double ldx = 2.0;
    long double lda = sqrt(ldx);
    lda = sqrtl(ldx);
alex000090
Re: RSQRT on ESP32
Postby alex000090 » Wed Dec 25, 2024 11:22 am
Thanks for your answer!
I mean is there a hardware or software implementation of "Fast inverse square root" algorithm on ESP32?
https://en.wikipedia.org/wiki/Fast_inverse_square_root
MicroController
Re: RSQRT on ESP32
Postby MicroController » Thu Dec 26, 2024 1:43 am
What do you mean? - As soon as you copy the six lines of code into your application, there is a software implementation.
Another option is to take the assembler instruction sequences for reciprocal square root from the Xtensa Instruction Set Summary, which should be faster than using "1.0f/sqrtf(x)", i.e. a floating point sqrt PLUS a floating point division.
alex000090
Re: RSQRT on ESP32
Postby alex000090 » Thu Dec 26, 2024 8:14 am
You are absolutely right. I mean there is better software algorithm whish was incorporated into esp-idf maybe. As well as, if I'm correct, in the CPU may be hardware RSQRT command which is can be used and also incorporated into esp-idf.
Users browsing this forum: ChatGPT-User, Qwantbot and 0 guests
