A Problem with ESP-WROVER-KIT (关于ESP-WROVER-KIT的问题)
AAAwen
Postby AAAwen » Wed Sep 20, 2017 1:29 am
I have a ESP-WROVER-KIT. But here's a question I encountered frequently.
My computer Often displays the blue screen of death when I turn on the ESP-WROVER-KIT.
我购买了ESP-WROVER-KIT开发板,但在启动开发板的时候电脑就蓝屏了,这个问题出现的很频繁,是否有办法解决这个问题。不胜感激! :oops:
Angus
Re: A Problem with ESP-WROVER-KIT (关于ESP-WROVER-KIT的问题)
Postby Angus » Wed Sep 20, 2017 1:58 am
That doesn't sound right! The ESP-WROVER-KIT has an FTDI 2232H USB to serial chip on it. The drivers for this will be loaded when you connect it via USB. Windows will blue screen if a driver causes a kernel mode problem, but there shouldn't be such a problem from the FTDI drivers & the ESP-WROVER-KIT.
Some suggestions:
- Check your Windows installation is up to date and the drivers for FTDI are up to date. For most recent versions of Windows, this driver will be installed automatically from Windows Update.
- Replace the USB cable you are using. If you're using a USB hub, try removing it or connecting to a different port on the computer.
Users browsing this forum: Qwantbot, trendictionbot and 4 guests
