Hello everyone! I have an ESP32-S3-WROOM-1U circuit. It receives power from a laptop via USB-C through a buck-boost converter. There are a few sensors communicating via the I2C protocol, and a GPIO output on pin 12 that I can toggle. I can upload the sketch without any issues using the Arduino IDE, and I can see the printed messages in the serial monitor.
Test 1: Switch on GPIO output on pin 12. The circuit works perfectly even if the USB D+ and D- pins are desoldered from the circuit (like powering from a power bank).
Test 2: Switch on the GPIO output on pin 12 and scanning for sensors via I2C. If the USB D+ and D- pins are soldered, the circuit works perfectly. However, if the USB D+ and D- pins are not soldered, the ESP32-S3-WROOM-1U seems to not boot properly, consuming only 29.3 mA, and GPIO19 is not pulled high.
So, if I power the circuit from a power bank, it doesn't work because the USB D+ and D- pins are not connected. What could be the problem/solution?
Why could this be happening? What does the USB D+ and D- pins have to do with the boot process?
Thank you!
ESP32-S3-WROOM-1U not booting without USB D+ and D-
Jump to
- English Forum
- Explore
- News
- General Discussion
- FAQ
- Documentation
- Documentation
- Sample Code
- Discussion Forum
- ESP32-S31
- Hardware
- ESP-IDF
- ESP-BOX
- ESP-ADF
- ESP-MDF
- ESP-WHO
- ESP-SkaiNet
- ESP32 Arduino
- IDEs for ESP-IDF
- ESP-AT
- ESP IoT Solution
- ESP RainMaker
- Rust
- ESP8266
- Report Bugs
- Showcase
- Chinese Forum 中文社区
- 活动区
- 乐鑫活动专区
- 讨论区
- ESP32-S31 中文讨论版
- 喵伴 中文讨论版
- ESP-IDF 中文讨论版
- 《ESP32-C3 物联网工程开发实战》书籍讨论版
- 中文文档讨论版
- ESP-AT 中文讨论版
- ESP-BOX 中文讨论版
- ESP IoT Solution 中文讨论版
- ESP-ADF 中文讨论版
- ESP Mesh 中文讨论版
- ESP Cloud 中文讨论版
- ESP-WHO 中文讨论版
- ESP-SkaiNet 中文讨论版
- ESP 生产支持讨论版
- 硬件问题讨论
- 项目展示
- All times are UTC
- Top
- Delete cookies
About Us
Information
