I have a load of the following types though and was wondering if I could use any of these instead
Won't work.Ideally I would use a single fixed resistor and capacitor to save space but can't think of a way of doing that.
If you use a low-impedance/constant-voltage source, e.g. the 3.3V supply from the ESP, the parallel strings won't affect each other;Similarly, setting up 4 voltage dividers would set up 4 parallel circuits but then the voltage across a specific thermistor would then be dependent upon the other legs (e.g. a thermistor may or may not be plugged in).
Can work too. But the GPIOs have an output impedance in the 10-100 Ohms range, compared to the basically 0 Ohms impedance of Vcc, so that may affect the accuracy a bit.I then thought maybe I need to power each divider using a different GPIO which I guess would logically work but not sure if this is correct?
Can also work. The integral pull-ups are in the 50 kOhms range, and may vary more or less with temperature, Vcc, between chips, and between pins, so not a great solution w.r.t. accuracy and repeatability.Also if the GPIO has a pull up resistor could I use that instead of the fixed resistor (although maybe I don't know what size it is).
Users browsing this forum: Bing [Bot], ChatGPT-User, Google [Bot], PetalBot, Qwantbot and 10 guests
