During testing, there was no noise to interfere with the speech detection.
What could be causing this issue, and how can I make my custom setup work?]
Thank all.
ESP32S3 output:
I (26) boot: ESP-IDF v5.3.2 2nd stage bootloader
I (27) boot: compile time Feb 19 2025 22:08:58
I (27) boot: Multicore bootloader
I (30) boot: chip revision: v0.2
I (33) boot: efuse block revision: v1.3
I (38) boot.esp32s3: Boot SPI Speed : 80MHz
I (43) boot.esp32s3: SPI Mode : DIO
I (48) boot.esp32s3: SPI Flash Size : 4MB
I (52) boot: Enabling RNG early entropy source...
I (58) boot: Partition Table:
I (61) boot: ## Label Usage Type ST Offset Length
I (69) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (76) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (83) boot: 2 factory factory app 00 00 00010000 00100000
I (91) boot: End of partition table
I (95) esp_image: segment 0: paddr=00010020 vaddr=3c040020 size=123d8h ( 74712) map
I (117) esp_image: segment 1: paddr=00022400 vaddr=3fc94400 size=02c4ch ( 11340) load
I (120) esp_image: segment 2: paddr=00025054 vaddr=40374000 size=0afc4h ( 44996) load
I (132) esp_image: segment 3: paddr=00030020 vaddr=42000020 size=32e48h (208456) map
I (170) esp_image: segment 4: paddr=00062e70 vaddr=4037efc4 size=05418h ( 21528) load
I (181) boot: Loaded app from partition at offset 0x10000
I (182) boot: Disabling RNG early entropy source...
I (193) cpu_start: Multicore app
I (202) cpu_start: Pro cpu start user code
I (202) cpu_start: cpu freq: 160000000 Hz
I (203) app_init: Application information:
I (205) app_init: Project name: example_vad
I (211) app_init: App version: 1
I (215) app_init: Compile time: Feb 19 2025 22:07:42
I (221) app_init: ELF file SHA256: 4914dda38...
I (226) app_init: ESP-IDF: v5.3.2
I (231) efuse_init: Min chip rev: v0.0
I (236) efuse_init: Max chip rev: v0.99
I (241) efuse_init: Chip rev: v0.2
I (246) heap_init: Initializing. RAM available for dynamic allocation:
I (253) heap_init: At 3FC97C90 len 00051A80 (326 KiB): RAM
I (259) heap_init: At 3FCE9710 len 00005724 (21 KiB): RAM
I (265) heap_init: At 3FCF0000 len 00008000 (32 KiB): DRAM
I (271) heap_init: At 600FE100 len 00001EE8 (7 KiB): RTCRAM
I (279) spi_flash: detected chip: generic
I (282) spi_flash: flash io: dio
W (286) ADC: legacy driver is deprecated, please migrate to `esp_adc/adc_oneshot.h`
I (294) sleep: Configure to isolate all GPIO pins in sleep state
I (301) sleep: Enable automatic switching of GPIO sleep configuration
I (309) main_task: Started on CPU0
I (319) main_task: Calling app_main()
I (319) EXAMPLE-VAD: [ 1 ] Start codec chip
W (319) i2c_bus_v2: I2C master handle is NULL, will create new one
E (329) i2c.master: I2C transaction unexpected nack detected
E (339) i2c.master: s_i2c_synchronous_transaction(888): I2C transaction failed
I (3209) EXAMPLE-VAD: [ 2 ] Create audio pipeline for recording
I (3219) EXAMPLE-VAD: [2.1] Create i2s stream to read audio data from codec chip
I (3229) EXAMPLE-VAD: [2.2] Create filter to resample audio data
I (3229) EXAMPLE-VAD: [2.3] Create raw to receive data
I (3239) EXAMPLE-VAD: [ 3 ] Register all elements to audio pipeline
I (3239) EXAMPLE-VAD: [ 4 ] Link elements together [codec_chip]-->i2s_stream-->filter-->raw-->[VAD]
I (3249) EXAMPLE-VAD: [ 5 ] Start audio_pipeline
W (3259) AUDIO_THREAD: Make sure selected the `CONFIG_SPIRAM_BOOT_INIT` and `CONFIG_SPIRAM_ALLOW_STACK_EXTERNAL_MEMORY` by `make menuconfig`
I (3269) EXAMPLE-VAD: [ 6 ] Initialize VAD handle
Pin Configuration:
i2s_config->bck_io_num = GPIO_NUM_12;
i2s_config->ws_io_num = GPIO_NUM_13;
i2s_config->data_out_num = GPIO_NUM_15;
i2s_config->data_in_num = GPIO_NUM_16;
i2s_config->mck_io_num = GPIO_NUM_2;
