Most of the examples I have seen are using numbers like int.
Thanks in advance
Thank you for the response. Will check ringbuffer. Saw the unit test and will check the code from there.ESP_Sprite wrote:A queue actually is made for items with a defined length; if you throw in strings it'll waste a bunch of memory. Maybe you want to look at the ringbuffer implementation (in components/freertos/ringbuf.c and components/freertos/include/freertos/ringbuf.h) instead? Unfortunately, I also do not have an example for that (although, if I recall correctly, there should be an unit test for that thing somewhere.)
Sounds good. Do you have any code samples for it I can check?kolban wrote:I have used queues to pass strings around in some of my projects. What I do is allocate storage for the string (so that it is not on stack) and then add a pointer to the string into the queue. The reader of the queue then sees a new entry which is a pointer to the string, works with the string and then deletes the allocated storage. The queue elements then become fixed size ... which is of course the size of a memory pointer. The un-written contract then becomes that the storage pointed to by the item on the queue has to be deleted/freed by the consumer.
sizeof(char *)
char *myData = "helloWorld";
char *myItem = malloc(strlen(myData)+1);
strcpy(myItem, myData);
xQueueSendToBack(myQueue, &myItem, portMAX_DELAY);
char *myReceivedItem;
xQueueReceive(myQueue, &myReceivedItem, portMAX_DELAY);
// Do something with received string and then delete it ...
free(myReceivedItem);
